Transistor Replacement K4112 => K3596
  • neilc6
    • Nov 2015
    • 1550
    Re: Transistor Replacement K4112 => K3596
    Maybe the discoloration is a red herring since that area generates a lot of heat and research indicates a bad CCFL bulb could also cause the backlight to shut off. Though, the burning smell indicates something is fried. The electrolytic caps are all Rubycon.
    • neilc6
      • Nov 2015
      • 1550
      I plugged the power supply board back in to measure the voltage on the CNE1 connector but the backlight stayed on and it's working again. But you know what they say about problems that go away by themselves....
      • neilc6
        • Nov 2015
        • 1550
        Ok, I found the real problem after looking at it again. Investigating the wire were it was scorched, the insulation had melted away where it contacted the tape they used to bundle the wires together and to tape it to the back of the panel. Shorts were probably causing the backlight to turn off. The burning smell was melting insulation.
        • sparks2112
          • Mar 2016
          • 20
          Hi got same board as in pics. For a evotel tv. And wanting know what it says on NTC1 its a power thermistor or ceramic cap. Mine blown to pieces so cant see what it says onit. Any help much appreciated. Thanks
            It is the inrush current limiter, hopefully someone has the board to get the Value.
            • sparks2112
              • Mar 2016
              • 20
              #26
              thanks for that bud. keep checking to see if any one had anything on this. but no joy.can buy these off rs components but 19 to choose from. could you recommend any? common ones etc. read a few threads you've been on about low ohms.diameter.watts etc. and mine was I think 13mm dia. but was badly blown and lost part now. seen a few 15mm.on there which would be ok. also some say application is for soft startmotor&switching power supply. some just for switching. and some for protection. which one would mine be for as could help narrow it down. for price of £1+ ill try a couple if they blow or cause more damage its all good was free tv so try anything lol. http://uk.rs-online.com/web/c/passiv...696D6974657226
                I would recommend 5 Ohms 15mm DIA.
                • sparks2112
                  • Mar 2016
                  • 20
                  #28
                  closed till Monday. but will try it,and let you know how I get on.
                  thanks pal
                    Once you install it, then you should check the ACV between the two legs after the TV is on for about 5~10 minutes to see what you get, the resistance of the NTC should go down when it get current flowing through it as it warms up.
                    • Haaheim
                      Bias matching replacement transistor - Parasound 2250
                      by Haaheim
                      Hi guys!
                      I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
                      According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
                      05-13-2022, 12:45 PM
                      ALIENWARE Area-51 i7-5820K Specification for Upgrade or Repair
                      This specification for the ALIENWARE Area-51 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 boardview and Area-51 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Area-51...
                      09-12-2024, 03:28 PM
                      ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                      This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                      ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                      This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
