Caps Question
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Caps Question
    If i need to change a capacitor and it the same uf/v,but slightly smaller in size can i use this ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Caps Question
    Yeah as long as the uf and voltage is the same you are fine, what series was the original cap and what series is the new cap ?
      • 31278
      Re: Caps Question
      dont force it in, if you stress the rubber bung it wont last.
      bend the legs at 90' angles with small pliers or something
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
