Common mistakes in electronic design
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    By Craig Hillman, PhD, DFR Solutions -- EDN, 12/14/2007
    Electrolytic capacitors
    [/quote]Although designers love electrolytic capacitors because of their high capacitance, they hate them because they fail over time. This love/hate relationship has led to a range of methods for derating and predicting lifetime. What are the best approaches? It all depends on whether you are derating voltage, ripple current, or temperature. With voltage derating, remember that electrolytic capacitors work best when you apply voltage to them. With no voltage, they have no dielectric and no capacitance. Although electrolytic-capacitor manufacturers have over the last five years improved these capacitors' low-voltage performance, try to avoid voltages below 25% of the rated voltage. At the other end of the spectrum, designers create capacitors by applying voltages 150 to 200% greater than the rated voltage. In addition, applied voltage tends to have minimal influence on lifetime. Because of this fact, the derating guidelines specify a maximum applied voltage of 80 to 90% of rated voltage, although some manufacturers apply 90 to 100% of rated voltage.
    Once you target a desired life cycle for your design, you can decide on the appropriate temperature derating. The industry-accepted equation is a doubling of life for every 10°C drop in temperature. Although some questions exist concerning the accuracy of this model, designers must be aware of three nuances. The first is that this life equation is relatively conservative—at least for reputable capacitor manufacturers. Vendors often define “lifetime” as 1 or 0.1% of failed parts, as opposed to the more standard MTTF (mean time to failure), which might yield a 63% failure rate. If your design lies between these extremes in desired lifetime, then it should be OK. Second, few applications experience constant temperatures. Users turn computers on and off, the sun rises and sets, and other similar temperature-affecting conditions occur. Make sure to incorporate variations in temperature into any lifetime calculation. Finally, all bets are off if there is elevated temperature due to an adjacent component, such as a resistor or a MOSFET. Some indications show that a highly localized temperature increase more quickly induces failure than the industry model predicts. Keep hot components away from electrolytics.
    Ripple current on electrolytic capacitors is an odd electrical parameter. Designers tend to ignore or forget it in most bill-of-materials calculations. Remember that “equivalent” capacitors are not equivalent when it comes to ripple-current ratings. And manufacturers can “uprate” ripple current. Some companies allow applied ripple current to be 150 to 200% of rated ripple current. They achieve this flexibility because ripple current primarily increases capacitor temperature, and vendors often specify capacitor lifetime at rated temperature and rated ripple current. The lower the temperature at which the design can operate, the higher the uprating margin on the ripple current.[/quote]
    PeteS in CA
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
  • Perry Babin
    Derating of polymer electrolytics
    by Perry Babin
    There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
    If they require derating, why would the manufacturer give them their rated voltage?
    This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
    https://www.mouser.com/datashe...
    10-24-2025, 11:57 AM
  • CapLeaker
    AcuRite 5 in 1 temperature sensor replacement repair
    by CapLeaker
    Got a new victim:
    AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
    A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
    B: stuck at some temperature and maybe updating once in 12 hrs or so.
    Easy solution is to go to AcuRite website and purchase the sensor. Right?...
    04-15-2025, 01:32 PM
  • chth96
    Is it no harm to replace with capacitor without ripple current rating?
    by chth96
    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
    Rubycon YK DataSheet (b...
    04-19-2024, 05:19 AM
  • Antonynl
    What are typical ripple voltages on a laptop motherboard?
    by Antonynl
    I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
    So I have two questions:
    1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
    2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
    Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
    12-09-2022, 06:51 AM
