Re: Replacement for TDA2050v
I see, so you use the Power MOSFET as the low side switch to sink the load.
I got this idea from an Everyday Practical Electronics (magazine) timer which they used as an auto shut off for a cheap multimeter. But switching the ground might not work so well for an audio circuit.Leave a comment:
How does VS- get to the circuit GND? I see it goes to the Center pin of the 3-pin connector. What is the 3-pin connector for?Leave a comment:
Next, connect the input ground to the VS- of the amp chip, directly. The way you have it here, you have a ground loop! Basically, higher currents - compared to the current of the input signal - will cause voltage drops across the GND wire, which basically will feed back into the input signal.
Also with regard to the interference between outputs/inputs/power, I was trying to fit the circuit on a very small space, but this is clearly to the detriment of the operation.
I personally would use a comparator with some hysteresis for the timer, but that's my way of doing things :P That may be another reason for bad sound quality, if the FET doesn't turn off cleanly, then it will have a high voltage drop across it, and the voltage at the amp will be less, which could lead to distortion at higher signal levels.
I'm struggling a little with the software, but here's the circuit with a few corrections.Last edited by JonathanAnon; 06-26-2015, 04:51 PM.Leave a comment:
"The second after posting this I spotted a few mistakes, but I'll correct them later ..." Please do because it does not look right at all.Leave a comment:
I was likefor a second there! xD
This is the circuit that I am playing with at the moment. The left side of the circuit is for a RC circuit + momentary switch, so I can hit the button and the speaker stays on for a few minutes (while I'm in the shower) then switches itself off automatically. I'm building it on stripboard, cos I'm poor and dont have any proper PCB tools :-)
Like (L,A), (L,B), (N,K), (N,M), (N,N), (N,O) ... etc...
Especially (L,B), this will decrease the coupling from the GND to the inverting input.
Point format: (Column/X, Row/Y) The strips on the board are the rows. Just saying, 'cause I don't want any confusion :P
This can cause distortion and even oscillation (worst case). That might be the source of your poor sound quality. I'd be surprised if the TDA2050 worked well with it like that!
Also, that 680uF capacitor on the feedback, shouldn't that be more like 10uF to 22uF?
You might want to add a capacitor to the 2x 22K resistor divider, to keep it more stable. The LM1875 datasheet shows a 10uF. Of course you don't have to follow the datasheet, but it isn't a bad idea to at least try.
I'm surprised how it stays on for a few minutes using only the gate capacitance of the FET!
Also, the reference board diagram in the LM1875 datasheet is really messed up. The components are out of alignment with the board. They didn't do quite as good of a job of eliminating ground loops as I would like ... weird.
-BenLeave a comment:
Would you believe me if I said that I'm still running it without the heatsink and it's still working perfectly. I have an infrared temperature detector and it didnt get that hot. But the plan is to fit in a proper heatsink anyway.
Finally, you can try using a lower impedance speaker if you can, that will give you more power output with the same input voltage.
The second after posting this I spotted a few mistakes, but I'll correct them later ...Last edited by JonathanAnon; 06-26-2015, 05:43 AM.Leave a comment:
@redwire
I've had it up and running for about a day now..... This circuit with the 1875T will simply not work without input filter caps, unlike the very similar circuit with the TDA2050V (which I had breadboarded and working fine without any filtration on the voltage source)
Also, reading the datasheet, I see that it is suggested to keep power supply traces/wires away from the input wires, to reduce coupled currents.
I tried out the 1875 for a few weeks, and I just dont like it.... I built the two circuits and the TDA2050V is somehow more powerful, much less noisy and it just works. So I'll probably buy a few on the cheap from China.
I'll work with a view to using a DC to DC converter in future projects and a chip that works with a higher voltage.
I suggest trying a D class chip in the future. Less power loss in the chip itself, so you don't have to worry about dissipating that as much as with a regular amplifier.
Oh well, one last thing is, you can do a bridge mode where you have two amplifiers driving one speaker, using a single ended power supply (no negative voltage rail). That will give you more output power, as the speaker will be able to get +-12V, instead of +-6V. (I think that is right, isn't it?)
I'll work with a view to using a DC to DC converter in future projects and a chip that works with a higher voltage.Leave a comment:
@redwire
I've had it up and running for about a day now..... This circuit with the 1875T will simply not work without input filter caps, unlike the very similar circuit with the TDA2050V (which I had breadboarded and working fine without any filtration on the voltage source)... I also initially left out the feedback cap on the TDA2050V circuit initially, thinking that it was not mandatory, but the circuit would not work at all without it in place...
@budm
input voltage is 12.2V and the voltage at the point between the resistor ladder (R1 and R2) is 5.98V, so it's pretty much 1/2Vcc
I had some problems with it sounded distorted / muffled after a period of time, but I added a temporary heatsink to the IC, and a pot to limit the input and it's been running fine for the last five hours. I find that if I allow too much signal on the input, the output will distort badly... But I guess this is due to a higher gain in the 1875T circuit.... Gonna keep testing it with voice and music inputs for a few days...Last edited by JonathanAnon; 05-03-2015, 11:32 AM.Leave a comment:
I've never had a TDA circuit stable without adding a cap across the feedback resistor (R6) and an RF cap across the input (R4). The IC will oscillate or pick up AM radio, or both. It sounds like distortion but on an oscilloscope you can see HF oscillations. If you can't get things to make sense or sound decent:
In parallel with R6 add a 33pF cap (for 24kHz -3dB).
In parallel with R4 add a 220pF cap (for 70kHz -3dB).Leave a comment:
OK, I thought you do the direct drop in with just the modification on the feedback, I did not know that you also added the biasing circuit.
So is the output pin sitting at 1/2VCC?Leave a comment:
You need to Bias the LM1875 pin1 so the output will be at 1/2 VCC since you are not using Dual power supply (+/-), you are using single power supply, it is also picky about how the circuit ground traces are routed. See app notes on how it is used, see Fig. 2.
https://cdn.badcaps-static.com/pdfs/...e9ec9f67d4.pdf
From what I'm aware the two resistor R1 and R2 put the non-inverting input's biasing voltage at 1/2VCC. C1 and R3 form a high pass filter on the input. And I presume that the 1M ohm resistor is just to discharge any stray voltage when the chip is off. C4 and C7 are filtering caps on the input voltage. R7 and C5 is the Zobel network. R5, R6 and C3 set the gain and C6 blocks any DC from reaching the speaker. I'm open to correction but that's my reading of it.
I have the circuit built pretty much the same as it is above, but I'll take into account what you said about the chip being fussy, and I'll build it with the EXACT values (well, within 5%) on the datasheet...Last edited by JonathanAnon; 05-02-2015, 04:34 AM.Leave a comment:
The datasheet for that 1875T says that it's input voltage is 16V-60V.. I tried swopping it in to the same circuit in place of the
TDA2050V, and changed the resistors to 200k and 10k in the feedback part of the circuit... But it sounds very low and completely distorted. I dont think it's gonna work without a DC-DC converter to boost the voltage >16V..
I didnt choose the TDA2003 initially cos it was only 10W, and I was planning on using the same circuit for a small guitar amp in the same plastic box / 4 ohm speaker combination. However, it may be a good option. There's a single supply circuit in the datasheet, and the chip operates with Vs of 8v-18v.
Of course I still have the option of just buying the TDA2050v on ebay or something... The chip has been around for years, and they only get rid of the thing when I decide to use it !!!
https://cdn.badcaps-static.com/pdfs/...e9ec9f67d4.pdfLast edited by budm; 05-01-2015, 02:48 PM.Leave a comment:
places like Dalbani probably have it, but those obsolete parts places charge a lot!Leave a comment:
Of course I still have the option of just buying the TDA2050v on ebay or something... The chip has been around for years, and they only get rid of the thing when I decide to use it !!!Leave a comment:
i just realised something.
the arcade stuff mostly used TDA2003 on a 12v supply.
it's almost a dropin for the TDA2050 with the same w/v curve.Attached FilesLeave a comment:
From a measurement of THD+N perspective, you may have a point, the THD+N figure for class D is worse, but I would contend the overall audio performance as humans perceive, and in the measurable 0-20kHz range, is better in most respects.
Class D really only has one disadvantage, and that's the noise components at higher frequencies due to switching noise. Most class D amplifiers switch around 300~400kHz to minimise filter sizes. This is well beyond any human hearing range so I fail to see how this could be considered an issue. Bear in mind most audio is only sampled up to a maximum of 192kHz. There are few subharmonics created by a stable clock source (such as a crystal) so even those should not be of a concern.
The process of generating audio is much more linear. The ideal class D amplifier would be purely DSP driven and would achieve perfect linearity. Most class D amplifiers use analog electronics (comparators and voltage ramps) to generate the switching pulses which introduce linearity errors although good design can minimise these. The only nonlinearities introduced by the switching process would be from the power supply sag and inductor saturation... both of which can be minimised by using proper design techniques and air-core inductors.
Contrast that to class AB and similar amplifiers. There is crossover distortion, which to eliminate requires large bias currents. Most manufacturers try to minimise this because it causes high power dissipation when operational. Also, the transistors themselves are quite nonlinear devices, something the feedback loop must compensate for.Leave a comment:
I've used TDA2030, 40, 50's in BTL (with a single-supply) but the turn-on thumps were huge and almost killed small speakers.
I would use one of the cheap DC-DC converters on eBay or DX to get higher voltage.
You need a heatsink on the LM1875T in your pic's, and negative voltage transient protection on power coming in.
Cloth acoustic-damping material in the box would help a lot.Leave a comment:
If you are constrained by a single supply of 12-14V, why not go BTL?
Guaranteed output of 20-25W into 4 ohms, no DC-DC converter, and you'll save board space without the output coupling caps.
Try a TDA7370 (dual-btl) or TDA7240 (single-btl).Leave a comment:
by r2digitalI have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...2 Photos
by BenassHello,
I am currently working on the Dual CV-1260 amplifier. Unfortunately, one channel has stopped working. After conducting some troubleshooting, I discovered that D34 is exhibiting an incorrect voltage drop, as opposed to D31, D32, and D33, which have a 1.2V drop. D34, on the other hand, has a 0.6V drop. This leads me to believe that one diode may be open.
F1 (the fuse) is showing 0.1V, and the channel is working fine. However, F2 (the fuse) is blown and reads -48V.
In summary, Line 39 has nearly zero voltage and is working normally, while Line 40...-
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...-
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... - Loading...
