Replacement for TDA2050v
  • JonathanAnon
    replied
    Re: Replacement for TDA2050v
    Hi guys,
    thanks for all the helpful responses.. Farnell and Radionics are the two suppliers that I use here in Ireland and both list the TDA2050 as gone.. Farnell says "No longer manufactured"...
    http://ie.farnell.com/stmicroelectro...45?ost=tda2050
    I actually have an LM1875T in my box here. I found a single supply circuit for it... I'll breadboard this and try it.. It is very very similar to the current single supply circuit that I am using with the TDA2050.
    Here's a quick look at my handy work. I'm trying to use just a smaller package chip as it's only on a small piece of stripboard. There no max current specified on the stripboard, but I'm sure it's probably good for 2A. Here's how it's looking so far.... (edit: I havent done the mic part of the circuit yet).
  • Longbow
    replied
    Originally posted by tom66
    Good Class D amplifiers have better distortion figures than Class AB.
    Untrue. This ethereal statement may appear in a text book somewhere. But as you would expect, there are always trade-offs. Class D was designed to offer efficiency and low cost which it does quite well. Class D amp modules are used almost exclusively to power the multiple channels in whole house area amplifiers, for example, which are designed for low volume audio at a reasonable price and with minimal heat. Class D is also great for car amplifiers, because the owners are not concerned with distortion levels.
    For more critical listening, the residual switching carrier of class D raises the noise floor unacceptably
    . The output stage must essentially reconstruct a sine wave from square wave, which is a difficult task even at one particular frequency, let alone the whole audio spectrum. And, the overall result is also affected by the particular drivers connected to it.
    Having said as much, class D audio modules do not differ much one from another. Have a look at the recommended switching frequency for a basis of comparison. If one particular type is NLA, it should not be a problem to install another (assuming the pinout is correct).
    replied
    well they arent the ones used on tv's then!
    replied
    Originally posted by stj
    class D - the D stands for Distortion!!
    Good Class D amplifiers have better distortion figures than Class AB. And they are much more efficient and work with lower input voltages for a given power output.
  • ben7
    replied
    Class D doesn't sound bad to me. There are some very good class D amplifiers out there. They are cheaper, lighter, and more efficient as well.
    replied
  • ben7
    replied
    Hah, mariush beat me to it. I was going to say, a class D amplifier needs either a very small, or no heatsink!
    Only downside is it's likely going to be an SMD chip.
    Hey, the LM1875 has the same pinout. Can't guarantee that it would be a drop-in replacement (looks like it would to me, with different feedback resistor values), you'll have to carefully check the specs to see if it would be ok.
    https://cdn.badcaps-static.com/pdfs/...e9ec9f67d4.pdf
    -Ben
  • mariushm
    replied
    Jonathan, tda2050 can still be purchased and it's an easy to use chip, you can find it at online distributors like Digikey or Mouser but since you're in Ireland it's probably better for you to use Farnell or TME.eu
    I would like to point out that TDA2050 *is* a 32w amplifier chip, but that's basically what the chip can do at almost the maximum input voltage it can tolerate and with some significant distortion. In real world, you don't want to push it that much because it would sound bad, a more realistic output would be about 25 watts but again, provided it gets enough input voltage.
    Check the datasheet : https://cdn.badcaps-static.com/pdfs/...31cada06bb.pdf
    On page 3, you can see it can do 32w with d=10% which is bad, and only at +/- 22v (or about 45v if you power it using single mode power supply).
    With 12-14v available from a car's battery, you'll only get about 5 watts from a TDA2050, as you can see on page 8, figures 8 and 10.
    The X axis on those graphs shows voltage in split mode power supply so your 12v is equivalent with +/- 6v on that x axis scale, and with that in mind you can look up on the y axis to see how much power you'd get from one.
    The tda2050 is also fairly inefficient at around 60-70%, you'd waste your car's battery with it.
    For a car amplifier working at 12v, you'd be better off with a Class D amplifier chip.
    replied
    http://www.st.com/web/en/catalog/sen...5/CL1503/SC979
  • JonathanAnon
    started a topic Replacement for TDA2050v
    Hi there,
    I've just worked out the perfect design for my car kit... rang to order a few of these chips and they tell me that the chip has been discontinued... Contacted my supplier and they cant suggest a suitable replacement...
    It's to work in my car, I need it to work with a 12v single source power supply and up to about the same wattage as the TDA2050, which is 32W... Anybody got any suggestions as to what I should use as a replacement...
    thanks,
    J
  • Coert van Dorsten
    Sansui Integrated Amplifier replacement volume control troubles
    by Coert van Dorsten
    Hi all you clever electronmic gooroos!
    I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
    10-15-2025, 02:54 PM
  • r2digital
    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
    by r2digital
    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
    04-18-2024, 03:50 PM
  • Benass
    Dual CV-1260 amplifier Component replacement.
    by Benass
    I am currently working on the Dual CV-1260 amplifier. Unfortunately, one channel has stopped working. After conducting some troubleshooting, I discovered that D34 is exhibiting an incorrect voltage drop, as opposed to D31, D32, and D33, which have a 1.2V drop. D34, on the other hand, has a 0.6V drop. This leads me to believe that one diode may be open.
    F1 (the fuse) is showing 0.1V, and the channel is working fine. However, F2 (the fuse) is blown and reads -48V.
    In summary, Line 39 has nearly zero voltage and is working normally, while Line 40...
    11-08-2023, 02:40 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • the_rem
    Unknown transformer : how to find a good replacement part ?
    by the_rem
    Hello guys,
    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
    04-23-2025, 01:48 AM
