Need specs on Motorola RF transistor SS4153
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I bought this transistor for $10 a couple years ago from a friend of mine. I'd been told at the time that it's a 40W VHF band transistor. It didn't work and i thought i got ripped off, but it turns out it needed to be fed more input power than my transmitter had at the time. The transistor looks kinda like this:
    Just that under the Motorola logo it says SS4153 and under that 943. I was unable to find any info on it. What i do know is that it is a NPN RF power transistor (at least it acts like one), but i have no idea about its ratings, like maximum supply voltage, current and power output.
    Now, i've thrown together a quick class C amplifier using it and it works when driven with 6W. Power supply for the whole transmitter is a switching brick of 20V and 2.5A and i tripped its protection several times in a row, so i would guess it currently outputs around 15-20W RF, given the typical 60-65% efficiency of RF bipolar transistors. I do not have an accurate RF power meter, and i left my 12 and 24v lightbulbs at a friends' house, so i can only tune for maximum output using my scope. I don't know what the output power actually is, but it's significantly less than 40W.
    It is certainly above the 10W level though, as i have used trimmer capacitors like these, pulled out of a 5W 144MHz amplifier:
    and they are getting very hot, it could certainly use better ones. I have mounted the transistor on a suitable heatsink with a fan on it. It runs fairly cool and the output signal is clean.
    I would guess it is a 24 or 28 volt device but i'm not sure and i don't wanna blow it up. So if anyone has heard of this SS4153 transistor i would appreciate any data on it.
    A working TV? How boring!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Need specs on Motorola RF transistor SS4153
    I found this, unfortunately, the link for the datasheet gives me a 404!
    http://www.codingintl.com/ss4153-p-11880.html
    Perhaps you might want to check some forums that are all about radios/RF equipment, they might have someone who knows what the specs are
    Or perhaps you might want to contact motorola (or freescale, not sure if they bought motorola's semiconductor business or what...).
    -Ben
    Muh-soggy-knee
      • 31138
      -Ben
      maybe it's in the folder.
      http://www.codingintl.com/pdf/datash...%20Transistor/
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Originally posted by stj
        Nope I don't see it in there.
        Muh-soggy-knee
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Yeah i found the link as well. Doesn't actually contain the datasheet.
          I contacted my friend who sold me this transistor and he told me he found it at that time (he's known to lie quite a bit, tho), and that it is 40W but it needs at least 15W input to get there, also that it should be powered with 24V and "not more than 5A".
          That's pretty much in line with what i've figured out by its behavior so far, so i'll have to believe him. I'll report back with more info in the following weeks.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            How are you matching/feeding it? You're getting less than a 5dB power gain.
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Well the matching needs some work. I'll be buying a BLY89 transistor a couple days from now, that should give it enough input power.
              Bipolar RF transistors of that vintage usually had 6-8dB gain, not any more. Only the japanese ones have 10dB. And don't get me started on the Russian-made KTxxx, those had like 4dB gain.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                its likely house marked.most motorola rf bipolars are mrf-xxx.
                • CoinCoin88
                  Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                  by CoinCoin88
                  I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                  Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                  09-15-2025, 03:36 AM
                • dicky96
                  Lynx RS4-2000 switch mode PSU does not start
                  by dicky96
                  Hi guys
                  This PSU is actually in an amplifier, but it is the PSU itself that has a problem
                  I have spent quite a lot of time trying to diagnose this and the more I get into it the more puzzled I become
                  It has a Standby, or Startup supply (15V) generated by a TOP245GN and this is working
                  The main SMPS is controlled by a SG3525A and it does not start up
                  According to the datasheet
                  https://pdf1.alldatasheet.com/datash...A/SG3525A.html
                  This SG3525A will shut down if pin 10 is high, or pin 9 or pin 8 are...
                  11-17-2021, 06:20 AM
                • MrCommunistGen
                  Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                  by MrCommunistGen
                  My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                  I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                  07-12-2021, 05:11 PM
                • jinu_j
                  How to test Subwoofer Amplifier with only a multimeter
                  by jinu_j
                  Hi Folks
                  Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                  Problem
                  I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                  Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                  Any advice would be appreciated...
                  08-29-2024, 02:05 AM
                • UserXP
                  Mackie CR4 amplifier no sound
                  by UserXP
                  Hi, people.
                  I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                  Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                  10-17-2020, 05:06 PM
