PC Graphics card
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: PC Graphics card
    Nope, had a crap DIY one that quit working after I forgot to discharge a cap
      • 30979
      damn
      well you located the area of the short,
      but the black caps re probably not the cause.
      it's probably a ceramic cap near them.
      if you had an esr / low ohms meter you could narrow it down like that, but as it is you need to make a list of all shorted ceramics etc and then try lifting them one by one.
      i'v done this a few times myself, so i know it's a long task.
      btw, just hope it's not the actual gpu or ram!
      • newtothis
        • Mar 2013
        • 1556
        • england
        Let me double check I am doing this right, Where do I put the - probe of meter?
        • newtothis
          • Mar 2013
          • 1556
          • england
          Originally posted by stj
          damn
          When I had the GPU and RAM off I did a quick resistance check, They seem to be ok
            • 30979
            you took all the bga off? damn!
            • newtothis
              • Mar 2013
              • 1556
              • england
              #26
              Yup, Total reball across all parts to make sure its all good Done properly with my IR station etc
              So just to make sure where do I have my - probe when checking this card for shorts?
                • 30979
                across each ceramic cap.
                most are in parallel so a low ohms meter may have helped narrow that down.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  #28
                  Ok MOST ceramic caps are giving less than 1ohm resistance in cct, out of circuit they are not allowing continuity at all (on ones I have pulled) if I put my probes to both pads from 1 cap it is giving me very little resistance. This normal?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Yes. That is normal. It means that something else in the circuit is giving the low resistance, not the cap itself.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      Still it seems odd to me that BOTH pads off the cap will allow continuity when nothing is bridging them. No doubt my logic is flawed with series vs parallel ccts
                      So when will I know when I have got it... Will removing it from cct change my reading in the cct itself or do I have to test every bloody little cap on this board out of cct?! Only around 200 of the f'ers!
                        • 30979
                        you will know when it shows less than 1 ohm off the board.
                        at that point, you will probably find that you dont see a short across the pads on the board anymore.
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          #32
                          board is looking rather unpopulated already lol
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            #33
                            OK just finished removing ALL the ceramic caps... Still continuity from pad to pad
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #34
                              Thought I would nosey round under the microscope... Looky at what I found.
                                • 30979
                                nice foto's
                                time to lift it - what is it, a smart fet?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #36
                                  Found another, Fluxed them up and flowed to remove the bridges, No difference to readings
                                  I think its a Smart Fet yes, Havent looked it up yet as getting late now
                                    • 30979
                                    maybe one of the fets is shorted, i hope you checked the board each time you lifted one.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      #38
                                      Yes lift, check, lift, check.
                                      Have 72 components off the board so far! lol
                                        • 30979
                                        got a foto of the other side?
                                        • newtothis
                                          • Mar 2013
                                          • 1556
                                          • england
                                          #40
                                          here
                                            MSI Gaming GT75 Titan 4K-011 Notebook GT Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GT75 Titan 4K-011 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan 4K-011 boardview and GT75 Titan 4K-011 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 08:44 AM
                                            MSI Gaming GT75 Titan-015 Notebook GT Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GT75 Titan-015 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan-015 boardview and GT75 Titan-015 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 08:40 AM
                                            MSI Gaming GT75 Titan-013 Notebook GT Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GT75 Titan-013 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan-013 boardview and GT75 Titan-013 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            MSI Gaming GT63 Titan-033 Notebook GT Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GT63 Titan-033 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT63 Titan-033 boardview and GT63 Titan-033 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 07:58 AM
                                            MSI Gaming GT63 Titan-032 Notebook GT Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GT63 Titan-032 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT63 Titan-032 boardview and GT63 Titan-032 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
