First a little bit of a back story..
Way way WAY back in high school, I was building a Van De Graff generator as a science project. The plans I was following called for a fiberglass tube, about 3 feet long, about 8 inch diameter.. Where was a high school kid going to find a fiberglass tube?? Thinking to myself that all that is really needed is something that is stiff and strong and not conductive, I hit upon using a stiff cardboard tube, the same length, same diameter and about a half inch thick..
Wanting to confirm my thinking, I asked my science teacher about the switch, telling him my reasoning.
He said, "If the plans call for a fiberglass tube, use a fiberglass tube. Always follow the plans!"
Well, I didn't like that answer very much. So I asked a different science teacher again, telling her my reasoning..
She said, "If the goals of the plans are met, then substitutions are acceptable"
Of course, this was the answer I wanted to hear.
So, my question...
When replacing capacitors, should I "follow the plans"?? I mean, if a board needs an 820uf 25v, USE an 820uf 25v...
Or, is there a little bit of leeway.. Say I only have an 820uf 50v.. Would that be a valid substitute??
If there IS leeway, how much?? I know that one shouldn't go DOWN.. IE Use an 820uf 10v to replace an 820uf 25v... But I would think a little leeway going up is permissible...
Totally off base here??
Thanx
So, my question...
Thanx
