Help choosing a new TV
  • HardCoreDore
    • Dec 2014
    • 11
    I am giving up on the Plasma as I don't know what else I can do to fix it. Luckily, I have the money to buy an inexpensive replacement.
    I'm currently using a 32" Sharp Aquos LCD panel that was manufactured in 2007. I absolutely hate it, but it was a cheap stop-gap.
    I have had my eye on this TV as "Worst Buy", currently has them on sale:
    http://www.bestbuy.com/site/vizio-m-...&skuId=4498002
    I'm not that familiar with Vizio, but some people rave about their LED flat panels as they have Full-Array Back lighting instead of edge-lit. I don't know much about their quality but my Samsung Plasma was not exactly dependable. I'd say it will be at least as dependable as it was (lasted 7 years with heavy use).
    Anyone have any experience with this TV? The smart TV function although neat is not all that important to me. I have a PS3, and a laptop that I use currently to stream video. I do like the fact that this set is 240hz (or at least 120 hz), and has gotten very good reviews on Cnet, and other sites. I also like that it has a QWERTY keyboard built into it's remote control. I may just end up using the Smart function often if I like the remote.
    Have the manufacturers finally wised up with regards to the "capacitor plague" and stopped using Chinese caps? The caps in my Plasma were garbage Chinese crap, which led to PS issues.
    thanks in advance
  • HardCoreDore
    • Dec 2014
    • 11
    Re: Help choosing a new TV
    bump. I'm fine with posting this somewhere else, but I figured this was the best place... No one has any suggestions?
    • valente222
      help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
      by valente222
      Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
      05-12-2025, 03:42 PM
    • ArMaaN376
      Samsung PS51E550 Plasma TV
      by ArMaaN376
      I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
      Opened TV cover & observed foll
      a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
      b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
      c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
      How to confirm Y -Buffer board...
      06-19-2024, 04:05 AM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • KYBOSH
      Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
      by KYBOSH
      Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
      No picture but you hear the TV static (white noise) playing loud and clear.
      The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
      But it seems they didn't get too far and just left it.
      When I first took a look I was amazed at how pristine the inside looked.
      Its as if the TV had been in a time capsule.
      Caps looked like they were just pulled off the self.
      Copper coils had no sign of corrosion on...
      02-01-2023, 11:10 PM
    • chazh
      LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
      by chazh
      This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
      I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
      The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
      09-01-2025, 08:56 PM
