Choke/coil/inductor: replacing or measuring
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I was troubleshooting a balance, and found that the power supply, a wall-wart block converting 230v AC to 9v DC, was dead.
    I managed to crack the casing cleanly open, and found that the choke had one of it's 2 legs broken from it's soldering point. The choke doesn't have a base, it's just the donut-ring with the copper wire wound around it, and two wires emerging from the bottom, which go through the circuit board, and soldered directly to it. The wires are quite thin, and the wall-wart looks like it took a knock, hence probably why the wire broke. The choke does have a covering of heat-shrink, and I can just see "25oC VW" on the heat shrink, no other markings. There was no glue holding the choke to the board either.
    I haven't tried to solder the choke back on again, the broken wire isn't long enough to go through the board anymore, so I'll need to solder a short bit of wire to extend it, but before I attempt that, thought I'd ask a couple of questions first.
    While I have the choke off, is there anyway of taking a measurement off it to determine its "value" or specification? I'm conscious that if I start messing with it, trying to solder a bit of wire to the leg, I might damage it, so if I need a replacement, I'll know what I need.
    Also, there are a couple of Fullcon 85oC GR caps on the board; should I replace them while it's open?
  • 999999999
    • Sep 2006
    • 774
    Re: Choke/coil/inductor: replacing or measuring
    You can probably get away with just cutting the heatshrink tubing off, inspecting the windings to make sure they don't "look" like the enamel is burnt off to make any shorts, then unwind a winding or two to get enough length to strip and solder it back to the board.
    Once you've done that if you have no suitable replacement heatshrink tubing, fold a piece of cardboard around it and tack the component and cardboard down with silicone caulking or epoxy or whatever you have that's reasonably heat resistant.
    The high (voltage) side capacitor usually lasts a lot longer than the low side output filter cap so if you have a spare cap for the output position I'd replace it.
    Then again, small current 9V DC wall warts aren't very expensive. While it is an exercise in learning failure and repair methods, it is often just as time effective to just buy a new one if you don't have a spare sitting in an drawer somewhere or don't have a charity shop (like Goodwill in the U.S.) that sells used electronics dirt cheap.
    Measurement requires an oscilloscope, inductance meter, or signal generator whose frequency is used to calculate inductance. Measuring it won't do much for you. If it's shorting out then the measurement will be off. If it's not then you don't need a replacement.
    Just take your time and undo a winding and you should do Okay.
    • FZG
      Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
      by FZG
      Hello there, helpful forum people!
      I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
      On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
      The original part...
      05-10-2023, 11:54 AM
      A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
      by momaka
      More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
      And a shot of the label:...
      01-26-2022, 03:26 AM
      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
      by momaka
      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
      http://www.rmac.kingwin.com/products.../abt_650MM.asp
      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
      What mostly drew me into buying it is its 2x PCI-E power connectors...
      03-29-2022, 11:34 PM
    • wnlewis
      New wire for my RDE3340 Whirlpool electric range
      by wnlewis
      OK. I got the rocker switch figured out thanks to the good advice on this forum.
      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
      This is a Whirlpool RDE3340 electric range.
      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
      Where may I find parts...
      01-08-2025, 11:21 PM
    • adelfr2009
      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
      by adelfr2009
      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
      09-28-2025, 10:21 PM
