Garage door RX unit (Cardin S38C) does not short relay to send opening signal
  • CoinCoin88
    • Nov 2014
    • 31
    • France
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver handles up to 4 channels, each of them having a dedicated slot on the PCB where a relay modules attaches. This relay module is wired to the main IC through 1 "signal pin" (+0V in normal condition, +5V when the correct coded signal is emitted by the transmitter). That main IC seems proprietary, I can't find anything on it (marked CARDIN ZELIG.2 XE15AB) but it looks fairly basic, hooked up to all dip switches and outputs +5V on dedicated signaling pins to trigger the control relays. Here there is only one relay module on channel A (CH.A). The Rx unit is connected to an output that goes to a master unit that is then wired to the opener (and various other appliance, you could even factor in an induction loop). That output is a NO contact (+24V) which, once shorted, is interpreted as the "opening signal" by the master unit. Below, an annotated picture of that main Rx PCB.
Name:	Capture d’écran 2025-09-15 à 11.07.59.png
    The "antenna / signal" section works perfectly fine: if you stick your ear next to the PCB, you can hear a very subtle high-pitch noise when you press the remote button, in sync with the transmitter led blinking. When the code is the same on Tx and Rx, the CH.A signal pin turns from +0V to +5V. This circuit goes to the last pin of the relay connector.
    The relay itself is a SY-9-K that clicks when its coil is energized with +9V. I have tested it on my bench and it works (clicks when hooking up my bench PSU and feeding +9V to one pin of the coil and GND to the other). However, in normal operation, both these pins receive +9V from the main PCB. There is what I suspect to be a NPN transistor for which I think the collector (bottom left?) is hooked up to one of the coil pin (the NA one; pin 10 of the connector). The base (bottom right?) receives +5V constantly through pin 8 of the relay connector. I am not sure if that's a transistot or anything else. It is marked 6B, with a "5" engraved vertically. Datasheets pointed me toward a transistor but... who knows. Picture below:
Name:	Capture d’écran 2025-09-15 à 11.13.40.png
    Here's where I'm stuck: I don't understand why the relay does not activate. Obviously something is wrong by my transistor knowledge is not that good and I don't understand what should happen. Basically :
    - normal operation: the transistor gets +9V / +0V / +5V (upper, left, right)
    - correct signal: the transistor gets +9V / +5V / +5V, but shouldn't that +9V go to GND (or anything lower) instead ?
    Measurements taken with my multimeter in diode mode on that transistor:
    - left (V) -> up (COM) : 0.653V
    - left (COM) -> up (V) : 1
    - right (V) -> up (COM) : 1
    - right (COM) -> up (V) : 1
    - left (V) -> right (COM) : 0.653V
    - left (COM) -> right (V) : 1
    Anyway, here where I'm stuck. Any support would be greatly appreciated: I suspect it's that transistor not doing its job, but it looks OK by my not-so-good standards on diagnosing them.
    Cheers!
  • lotas
    • Jan 2016
    • 4716
    • Russia
    The top one is a diode, connected in parallel to the relay winding, the bottom one is a transistor, the base on the left, the emitter on the right.
    • CoinCoin88
      • Nov 2014
      • 31
      • France
      Thanks for the input. For the diode I had figured out for the diode it was probably this. Thanks for confirming. In diode mode I see a voltage drop of 0.23V on the diodes (left to top ; right to top).
      So the bottom one is a PNP transistor. Is there any indication it is bad, based on the readings I have? I am no good at understanding what it's supposed to do.
        • 31170
        the transistor is a switch linking 5v to the relay coil when it gets a signal on it's base pin.
        if you short the emitter and collector together the relay should turn on.
        • CoinCoin88
          • Nov 2014
          • 31
          • France
          So if I'm reading properly and mapping to my measurements :
          - in absence of any signal, B = +0, E = +5V, C = +9V
          - correct signal sent, B = +5, E = +5V, C = +9V.
          That last part is not normal because the collector should drop to 0V is that right? Hence, this transistor is bad indeed?
          • lotas
            • Jan 2016
            • 4716
            • Russia
            On the second terminal of the relay, which comes where the negative voltage (GND),
            • CoinCoin88
              • Nov 2014
              • 31
              • France
              I'm not sure I follows you. Did a part of the your message get truncated?
              • lotas
                • Jan 2016
                • 4716
                • Russia
                The transistor marked "6B" is BC817-25, and it is NPN, which means there should be a negative voltage on the emitter.
                • CoinCoin88
                  • Nov 2014
                  • 31
                  • France
                  Ah! OK, then I need to trace where this pin is fed from. By the PCB design and the pics I have with me right now, here's the path.
                  Seems to be leading to another transistor (odd that it would serve a different pin on CH.C and CH.D connectors but who knows). Maybe a new lead to check on when I'm back home tonight !!
                  • CoinCoin88
                    • Nov 2014
                    • 31
                    • France
                    Couldn't edit my post above to add the picture, sorry
Name:	Capture d’écran 2025-09-16 à 12.46.37.png
                    • lotas
                      • Jan 2016
                      • 4716
                      • Russia
                      Your electrolytes are leaking and the vias are corroded, you need to remove all the electrolytes, wash the board, replace them with new ones, restore the vias...
                      • CoinCoin88
                        • Nov 2014
                        • 31
                        • France
                        Woaw amazing you were able to spot this. I had noticed some vias were "different" from the others but would never have linked that to leaking electrolyte caps. Thanks for spotting, I will add that to the list of things to fix.
                        I'm now home. Following up on the track I posted earlier and your suggestion, here's what I find:
                        Click image for larger version  Name:	Capture d’écran 2025-09-16 à 22.27.52.png Views:	0 Size:	1.81 MB ID:	3726545
                        The transistor in-between where the three tracks converge is marked B6 (+ unreadable vertical letter) so I suspect it's the same as the one from the relay board. Readings in diode mode:
                        - left (V) -> top (COM) : 0.445V
                        - left (V) -> right (COM) : 1
                        - all other to 1
                        Sounds like left to right should be B to E and it should read identical to B to C. If that's right, maybe I found my culprit there ?
                        edit: some more measurements when powered up with +12V: the pin from the main IC connected to that transistor is at constant +5V (regardless of signal received or not). So the transistor basically has E +5V, B GND, C +5V. Doesn't sound right but also can't understand why the pin always outputs +5V.
                        • CoinCoin88
                          • Nov 2014
                          • 31
                          • France
                          Well, an update!
                          After replacing the transistor I thought to be faulty, all now works as intended: the new one now provides a ground for the transistor on the relay board, which is able to open the relay coil circuitry on one end when it receives the +5V signal when the remote sends the proper code. Bottom line, it's fixed!
                          I do not fully understand the role of that transistor (from post #12): the emitter goes through a resistor and to a constant +5V from the IC while the base is connected to GND. The collector goes to the relay board and then through a resistor to the other transistor at its emitter.
                          Would anyone be able to explain the circuitry ? I'm happy that it works, just a bit frustrated that I don't understand all that happens
                          • lotas
                            • Jan 2016
                            • 4716
                            • Russia
                            You have an incorrect understanding of the pinout of an SMD transistor: the base is always on the left, the emitter on the right, and the collector on top.
                            • CoinCoin88
                              • Nov 2014
                              • 31
                              • France
                              I had understood that. But then what's the purpose of that transistor (that you annotated) where : base is linked to a pin of the IC always delivering +5V, emitter is grounded, and collector links to the emitter of a secondary transistor (through a resistor) which sits on the relay board and acts as a grounding switch ?
                              To me it sounds like that first transistor could have been skipped and just ground the emitter of the secondary transistor.
                              • lotas
                                • Jan 2016
                                • 4716
                                • Russia
                                I don't know how this board works, but it's clear that this transistor is controlled by a controller with firmware built into it (the brain). If it controls this transistor, then it doesn't always get these 5v to its base. The controller can, in the event of some kind of accident (a faulty sensor, etc.), disconnect this power to the base of this transistor.
                                  Lift Master garage door opener with WiFi capability application through your phone
                                  by sam_sam_sam
                                  I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                                  This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                                  01-21-2023, 08:31 PM
                                  Linear Garage Door Opener Control board took a crap install a new control board back normal
                                  by sam_sam_sam
                                  I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                  02-08-2025, 06:52 AM
                                • CuriousJohn
                                  Burco boiler power problem
                                  by CuriousJohn
                                  Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                  Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                  This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                  12-22-2024, 10:25 AM
                                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                  by sam_sam_sam
                                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                  I am comparing them to a brand new one that I installed
                                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                  I going to let it run for several days before I remount back on the wall next to the...
                                  09-05-2024, 06:48 PM
                                • valvashon
                                  Repair Success! Middle Atlantic UPS2200R-IP
                                  by valvashon
                                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                  02-06-2024, 12:54 PM
