Behringer Eurolive B205D repair - help identifying transistor
  • magneh
    • Apr 2014
    • 585
    • Portugal
    Hello
    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
    Still, I need to replace this transistor.
    I found a schematic, and also there I see it as T1, and with reference of 113, which is a bit confusing to identify...
    On the IC itself, I have 3 dots on top and GS O, bit hard to take in pic.
    Can someone help me getting this part right?
    Thank you
  • lotas
    • Jan 2016
    • 4458
    • Russia
    MOSFET -MMBFJ113 Click image for larger version
    • CapLeaker
      Leaking Member
      • 7972
      I guess there are a few lost posts...
        • 30917
        lost posts, lost uploads - or atleast the links are broken,
        but darkmode is back - hell yea.
        • CapLeaker
          Leaking Member
          • 7972
          Dark mode is back! I guess pictures are starting to reappear too!
