Resistor with "1:R2" printed on it.....what value should I read?
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Has this two dots any meaning? Because there are several and I would say they measure about 11 ohms.........however, my common sense tells me that they should be 1.2 ohms........right?
    It's a 1210 SMD resistor, just if it helps.
    Regards,
    Francesc.
  • truclacicr
    • Apr 2019
    • 343
    • australia
    I would think the same as you. I don't recall ever seeing that marking style, though. Can you show us the whole PCB? Maybe we could infer an appropriate value by determining the functions of the resistors in the circuit.
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
ID:	3657125It belongs to a Schneider Solar Inverter
      • truclacicr
        • Apr 2019
        • 343
        • australia
        It seems to me that the resistor should carry a reasonably high current, so 11 ohms doesn't make sense.
        • Francesc V.
          Tempus fugit
          • Nov 2022
          • 231
          • Catalonia
          These two dots, with a little bit of imagination turns into an 8 (eight)...............so I guess that these resistors might be 18R2 :-)
          It makes sense as long as some in the circuit measure 18.4
          What do you think?? Do we accept an eight? xDD
          • petehall347
            • Jan 2015
            • 4439
            googles take on it ..
            The image shows two surface-mount resistors, both marked with "18R2", which indicates a resistance value of 18.2 ohms. These resistors are likely metal foil resistors, known for their precision and stability, and used in applications requiring accurate resistance values.
            Foil resistors are constructed with a thin metal foil mounted on a ceramic substrate, offering excellent heat conductivity. The markings "18R2" denote a resistance of 18.2 ohms, with the "R" acting as a decimal point. These components are typically used in circuits where precise current control or voltage regulation is needed.​
            • truclacicr
              • Apr 2019
              • 343
              • australia
              Try to determine how much current those resistors are required to carry in that circuit, then calculate the wattages to see if they make sense.
              FWIW, D10 is a 1A 40V Schottky Diode (VS-10BQ040-M3/5BT):
              https://lt.rsdelivers.com/product/vishay/vs-10bq040-m3/5bt/vishay-40v-1a-schottky-diode-2-pin-do-214aa-vs-m3/5bt/5431566P
              https://www.vishay.com/docs/93335/vs-10bq040m.pdf
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                Thank you all for the responses and your time.
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
