How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
    • Jul 2011
    • 6045
    I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
    I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
    what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
    I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    This appears to be one of those voltage doubler input stage PSUs so likely you'll need at least 190V or so DC to get this thing started (set to 220V operation). At 160VDC or lower it will likely not work right.
    • CapLeaker
      Leaking Member
      • 8214
      What battery pack?
        • Jul 2011
        • 6045
        Is a 200 volt battery pack doable and if so how would you go about changing it yes a this voltage would be a little bit dangerous to play around with because the highest MPPT controller voltage I have seen so far is 160 volts is there any that go higher voltage than the ones that I have seen so far
          • Jul 2011
          • 6045
          What battery pack?
          This is the question that I am asking is it doable or not and feasible or not is another question
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hooray it's one of those TL494 designs... i.e. old slower design, I'm surprised it would stay stable at 1V looking at the parts here...
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              You'll have to build your own BMS as probably most BMS won't handle such high voltages. And I don't understand how you're integrating mppt into this, this is completely different, you have to get a fairly stable power input and not depend on sunlight.
              Another way to help make things easier is to design your own APFC and get rid of the input stage.
                • Jul 2011
                • 6045
                Surprising enough it is very stable for charging battery packs this the reason for posing this question like I have
                I know when I was screw-ing around with computers switching power supplies trying to change voltage out and realizing that the this concept is not practical because you would have redesigned the hole circuit to be able to accomplish this and when I saw this design and it seems work decently designed yes it not perfect but it does the job that it was designed to do which is to voltage and current and being adjustable
                Now there is a version that is 0 to 15 volts or 0 to 30 volts and the 0 to 30 volts the 0 to 15 volt one supposedly can deliver 1000 watts I do not know if it is the same design or not the 0 to 30 volt one I can not remember what the wattage on this model but it is only available on AliExpress at the moment every once in while some EBay seller will have for a period of time and then they disappear for a period of time again
                  • Jul 2011
                  • 6045
                  I have two questions
                  one how easy is it to design APFC
                  two I was not going to rely on sunlight but also battery power as well
                  I not suggesting that this feasible or not exploring possibly of doing something like this but like I mentioned earlier it might be worth it in the long run
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I don't think the transformer on that board can pass 500W or at least it seems a bit small IMHO. Then again it doesn't need to have as many windings as an ATX PSU.
                    And effectively building an APFC is building a wide input range boost mode 300V PSU. These can now deal with lower battery voltage input.
                    • CapLeaker
                      Leaking Member
                      • 8214
                      The APFC idea is pretty good, but since I am lazy @$$ fux, how about a small 24VDC or 48VDC to 110 or 220VAC inverter? The effiency is down the shitter, since you converting DC to AC and then back to DC. But I am sure the AC switch for the voltage doubler circuit is there for a reason. I guess it’s pick your poison. Either deal with inverter and crap efficiency, or deal with high voltage DC (I suppose you could put various battery packs in series like five 48V packs in series for 240VDC, but when you charge them you have to charge 5 packs each).
                        • Jul 2011
                        • 6045
                        There are trade offs no matter what option you choose but question is which one is lesser of the two options evils you will give up something the real question is which one is a better option effectively wise battery charging that you can adjust the voltage and current and be the most efficient way to do I saw YouTube video on a boost converter that might be the option that I am looking for this only issue is that the lowest voltage seems to be 12 volts it might be lower but the person doing the review did go with an input voltage lower than 12 volts if I decided to try this boost converter I would have to try at lower input voltage and see how it preforms
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          The APFC / boost converter is not going to be an easy solution of course. You could find a PSU with discrete APFC and just ripping off that section, though a lot of recent PSUs with APFC integrates the APFC with the switcher making it tough to separate. I'm not exactly sure how well the APFC will work with continual low voltages either, mainly because it probably still is expecting 120VDC to maintain most of the power.
                          Just using that inverter is much easier.
                          • CapLeaker
                            Leaking Member
                            • 8214
                            The inverter idea is the easiest. But the best idea is straight DC for efficiency.
                            But I wouldn’t have a use for a CC CV, High DC input voltage PSU.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              You really have a 1V battery pack to charge to test stability?
                              I'd imagine at really low voltages it'd oscillate. Average will still be the correct voltage but will be surging up and down. Maybe so fast you need a 'scope to see it.
                              But I wouldn't have a use for a CC CV, High DC input voltage PSU.
                              Technically a inverter that goes straight to 220V won't be too bad for efficiency. Then again it's still doing transformer -> half bridge rectifier -> filter -> H bridge -> full wave bridge rectifier -> chopper -> transformer, you could cut out a lot of that too
                              • CapLeaker
                                Leaking Member
                                • 8214
                                Technically an inverter that goes straight to 220V won't be too bad for efficiency. Then again it's still doing transformer -> half bridge rectifier -> filter -> H bridge -> full wave bridge rectifier -> chopper -> transformer, you could cut out a lot of that too
                                Oh yes! All the unnecessary chit would have to be gone. Agreed!
                                  • Jul 2011
                                  • 6045
                                  Could you please share a website link where I can find a decent one that I do not have to pay an arm and a leg for
                                  • CapLeaker
                                    Leaking Member
                                    • 8214
                                    Riiight... Places like Ali and whatever is a no go for you guys at the moment due to these forking tariffs... I suggest you look for a (broken) inverter or UPS in a recycling centre and or facebook market place, Ham fleamarket etc. Or a Canadian mailing address and drive over the boarder.
                                      • Jul 2011
                                      • 6045
                                      Is this what you are talking about
                                      https://www.ebay.com/itm/39660749083...Bk9SR47lq-vaZQ
                                      • CapLeaker
                                        Leaking Member
                                        • 8214
                                        Dayum. That is a cheesy and thin looking board. No protection and 150w? Looks more like 15w to me.
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                                          This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 03:28 PM
                                          Acer Aspire A317-53-369X + 17.3" Options Pack Care Gold Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A317-53-369X + 17.3" Options Pack Care Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-369X + 17.3" Options Pack Care Gold boardview and A317-53-369X + 17.3" Options Pack Care Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-07-2024, 03:10 AM
