Hello, I could not find the information of this diode in the photo. What is the information of the diode?
What is the information of this diode?
by Francesc V.Hi:
I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
Any idea? it's a 6.6V zener?
by paul362Hi all can anyone help to find a replacement diode with markings, LT9B1 2 UG ?
picture attatched.
Cheers : Paul... -
by Srdjan01Hi everybody.
I'm trying to fix this toothbrush that doesn't wanna start. And I need your help.
Just to inform you that I'm supperbeginner
First photos are from internet because I did not took a photo of whole board.
I have noticed that fuse marked with "E" near the battery pole is bad and decided to short it with a "proper calibrated wire" as one would say.
Now, when I apply 1V from the power supply, limited to 500mA, one of the component stick out from the rosin mist. CHC N2AB (or some variation of that letters) is the hottest...6 Photos03-05-2025, 10:05 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by GentianI have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
- Loading...
