What is the information of this diode?
  • poker
    • Dec 2021
    • 28
    • Türkiye
    Hello, I could not find the information of this diode in the photo. What is the information of the diode?
    • 30983
    something like this maybe?
    https://www.littelfuse.com/products/...p4sma/p4sma62a
    • lotas
      • Jan 2016
      • 4557
      • Russia
      S1J
      • poker
        • Dec 2021
        • 28
        • Türkiye
        lotas thank you so much bro
        • Francesc V.
          Diode marked as "E57".........not able to find it by reference
          by Francesc V.
          Hi:
          I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
          I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
          It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
          Any idea? it's a 6.6V zener?
          06-14-2025, 09:56 AM
        • paul362
          Trying to find a replacement Diode.
          by paul362
          Hi all can anyone help to find a replacement diode with markings, LT9B1 2 UG ?
          picture attatched.
          Cheers : Paul...
          09-06-2023, 10:35 AM
        • Srdjan01
          Oral-B IO Series 6
          by Srdjan01
          Hi everybody.
          I'm trying to fix this toothbrush that doesn't wanna start. And I need your help.
          Just to inform you that I'm supperbeginner
          First photos are from internet because I did not took a photo of whole board.
          I have noticed that fuse marked with "E" near the battery pole is bad and decided to short it with a "proper calibrated wire" as one would say.
          Now, when I apply 1V from the power supply, limited to 500mA, one of the component stick out from the rosin mist. CHC N2AB (or some variation of that letters) is the hottest...
          03-05-2025, 10:05 AM
          by Vesko356
          08-11-2023, 03:27 AM
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
