NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    • 31265
    a modern linear regulator can operate about .5v above the output, you dont need a 2v overhead.
    that said, if this is all for an esr meter then open the meter and look at the power circuit.
    it's probably all 5v from a regulator anyway.
    • brispuss
      Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
      by brispuss
      Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
      Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
      I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
      12-28-2022, 02:58 AM
    • unimatrix93
      TV backlight zener diode
      by unimatrix93
      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
      The led strips has 9 6V leds.
      02-10-2025, 12:13 PM
    • nev1001
      What zener diode might fix the sound on Maestro Mayhem gaming chair?
      by nev1001
      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
      I think an issue could be a zener diode (or capacitor) which has shorted out.
      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
      04-17-2025, 05:09 PM
    • Vincenzo2
      Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
      by Vincenzo2
      My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
      Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
      I put some pictures here to show that it is labeled "M7"....
      09-07-2023, 07:43 PM
    • hobostove
      Corsair RM1000e - Help identify 5VSB Zener diode
      by hobostove
      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
      There's a 22ohm resistor that's melted and open, but it still has the bands.
      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
      It looks like the diode connects the source and drain of a TNY284...
      03-27-2025, 02:25 PM
