Flexbv Or Nextbv Softaware for PCB Viewer?
  • Stanley1843
    • May 2024
    • 48
    • Swiss
    Hello guys.
    What software between Flexbv & Nextbvdo do you beleive is better for desktop and laptop motherboards, smartphones and VGA cards?
  • madscientist750
    Replacing electrolytic caps by solid caps on old motherboards
    by madscientist750
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    10-19-2025, 06:10 AM
  • inflex
    FlexBV FREE Edition - Modern Boardview software for Win, macOS and Linux
    by inflex
    Now available, FlexBV Free edition is a slimmed down product of the full licenced version.
    https://pldaniels.com/flexbv5 ( available on the downloads page or most of the way down on the main page )
    If you're looking for a modern alternative to existing boardview programs that's also cross platform then consider giving FlexBV Free a go.
    So what's missing?
    * Schematic/PDF coupling
    * Butterfly view
    * Donor board part searcher
    * Jobs
    * Annotations
    What's new/improved compared to others?
    * OBData...
    10-10-2023, 12:29 AM
  • IBRAHIMHASSAN
    Asus r510lb laptop board viewer files
    by IBRAHIMHASSAN
    Hello friends
    i need some help to get the board viewer files for the above model number( asus r10lb) i cant pinpoint the heated component the board is crowdy so i want to use board viewer but i need file please
    thanks in advance
    10-10-2022, 06:57 PM
  • Thefixinator
    Having trouble getting Flexbv to work to view openboarddata files
    by Thefixinator
    Hey guys, I'm feeling like a noob trying to get flexbv to work to be able to download and view a particular board view of a mac mini 2018. Ive tried to read how to use the open board data but it's appearing to be a little confusing on how to actually look up a particular boardview. I'm using the free version to get my feet wet with the software. Ive checked to make sure under the program preferences the openboarddata.org is in the right spot which appeared to be there by default but im not able to open up and board preference to search for a specific board view. I'm probably confused on how it...
    06-18-2025, 11:51 PM
  • qwerty99
    Xbox 1.6 Motherboards and Polymer Capacitors
    by qwerty99
    Hello!
    I need to change the capacitors on my three original Xboxes.
    Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
    The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
    The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
    I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
    06-26-2022, 12:53 AM
