Help Identifying a component and advices needed
  • bohaboha
    • Nov 2012
    • 972
    • sweden
    Advice on this: VPMS2GMB I found some but they don't have the same indications on the chipset
    Does it have to be exactly the same or is it enough that it is a VPMS2GMB
    Identification: this Ic Q80B-104HIP when I search with Q80B-104HIP I get results for :EN25Q80B-104HIP as you can see the first characters are not in the picture is :EN25Q80B-104HIP the right one ?
    the last mentioned are from a samsung mainboard BN41-02751B-000
    Now the last one ic from USB AMCAP DIGITAL MICROSCOPE is blown but you can almost see many signs but not all of them if you can assist with some identification and especially with advice I am very grateful​
  • bohaboha
    • Nov 2012
    • 972
    • sweden
    here the pictures
      • Jul 2011
      • 6031
      I have to wonder what is blowing these devices up what part of the circuit are these devices in on these boards
      • bohaboha
        • Nov 2012
        • 972
        • sweden
        I am also surprised that they blew up it is the small usb microscope circuit do not know what has caused it to get very hot then boom I think it is interesting to know the reason first wanted to find the chipset but could not identify maybe someone who have the same equipment or has the same problem can contribute
        some information
        • truclacicr
          • Apr 2019
          • 297
          • australia
          https://www.esmt.com.tw/upload/pdf/E...800C_Ver.J.pdf (see page 1 - "Eon products’ New Top Marking")
          https://www.esmt.com.tw/upload/pdf/E...Q80B_Ver.E.pdf
          • bohaboha
            • Nov 2012
            • 972
            • sweden
            Originally posted by truclacicr
            thank you
            • bohaboha
              • Nov 2012
              • 972
              • sweden
              no idea about the blown part?
              • truclacicr
                • Apr 2019
                • 297
                • australia
                It would help if we knew its function. Perhaps a photo of the complete PCB would put it into context.
                You could try cleaning up the "smoke" to expose the character preceding the "2".
                • bohaboha
                  • Nov 2012
                  • 972
                  • sweden
                  Thank you I have tried to clean with care so as not to get anything off until we manage to define which numbers or letters and yes think I see MX2330 so if it is correct then it is missing a letter or a digit.
                  • truclacicr
                    • Apr 2019
                    • 297
                    • australia
                    I only found LMX2330, but that's a completely different IC.
                    • bohaboha
                      • Nov 2012
                      • 972
                      • sweden
                      yes i found that too but what's about I.MX2330 this one looks to be more used in camera world . then i think it will not be easy to find it unless i find a broken one .
                      but the rest of the number under can those help to find? thank you
                      • truclacicr
                        • Apr 2019
                        • 297
                        • australia
                        IMX2330 is an image sensor, not a controller.
                        https://www.sony.com/en/SonyInfo/New...01411/14-112E/
                        I can't see the markings on U6, but I think it's an EEPROM (24xxx) or some kind of memory IC. If it's capacity is small, then I expect that there would be flash or ROM code inside the controller, in which case it would be game over. Otherwise, if the capacity is large, then you may still be in with a chance.
                        • lotas
                          • Jan 2016
                          • 4536
                          • Russia
                          U6 - 24C64
                          This is where the GL862EX stands.
                          • sofles
                            Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
                            by sofles
                            Hi there,
                            Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
                            With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
                            05-30-2025, 01:11 PM
                          • MyBrainIsAStrainer
                            Quicko T12-955 Repair (Board Rev 3.3): Help identifying components needed
                            by MyBrainIsAStrainer
                            Hello! I'm newbie-ish in electronics and hope you can help me.
                            I use a Quicko (or Quecoo, not sure which is correct) T12-955 soldering station as my daily driver. Recently, I had a mishap. While changing tips, the metal contact inside the handle got bent and must have shorted against some other contact. Since then, the station only shows "Error" on its display. I fixed the bent contact but the error didn't go away. In fact, now it's completely dead.
                            After opening it, I found obvious two faults: A chip that looked molten (U5), and another chip which got very...
                            06-17-2023, 10:59 AM
                          • Dvsr
                            Help needed identifying SOT-23 component with marking "AKE87"!
                            by Dvsr
                            I am trying to fix a dead lane switching track piece for slot cars made by Carrera. I measured component on PCB and found out that at least two components have gone bad. I suppose they are transistor which drive the solenoids. Their marking is AKE87. Those components are marked T3 and T4 on circuit board. I tried to search that marking from the internet but didn't find anything. I would like to know if those are transistor and what could be used as a substitute.
                            Any help is greatly appreciated! Thanks in advance! ...
                            03-24-2023, 10:30 AM
                          • Ado02
                            DELL 15 3505 LA-K001P PD1 - Identification Needed
                            by Ado02
                            Can anyone help me identify the PD1 component on LA-K001P motherboard?...
                            05-06-2022, 09:21 AM
                          • Shulgin
                            Acer predator XB241YU Component identification
                            by Shulgin
                            I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                            After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                            In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                            I...
                            05-11-2024, 11:06 AM
