Epson-XP305 EEPROM Dumps
  • nogger
    • Aug 2010
    • 190
    Hi all, posting this in here as there doesn't seem to be a group for printers.
    I have one of these printers that complains of 'non Epson cartridge in use' & i believe the firmware has been updated while it was connected to the network. I refuse to paya small fortune for Epson ink (more expensive than Champagne)
    I am looking to re-flash the firmware to a previous version & then disconnect it from the network so Epson wont update it again. Does anyone have any eeprom dumps or know where i can get them. I will post the current version shortly, i think i will have to remove the eeprom to flash it as the Epson utility will not allow to downgrade
    Thanks in advance
    Nogger
  • desert-rat
    • Mar 2014
    • 4103
    Re: Epson-XP305 EEPROM Dumps
    I know some of the printer cart.s have a chip on them . Some of the web sites that sell re-ink kits have the chips . Some of the cart. chips can be re programed when you re fill the cart.
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
    • aboumohamed
      Good dumps for Epson xp-332 & Epson xp-335
      by aboumohamed
      02-24-2023, 08:17 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • davg
      Home network connection problem
      by davg
      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
      03-06-2021, 07:13 AM
