SMD GHS 05
  • ubicaram
    • Feb 2023
    • France
    SMD GHS 05
    Can someone tell me what type of component this is?
    referenced GHS 05A
    Fuse?
  • lotas
    • Jan 2016
    • 4813
    • Russia
    SMCJ188CA, Bidirectional Protection Diode 1500W 188V [SMC/DO-214AB]
    • truclacicr
      • Apr 2019
      • 352
      • australia
      https://www.vishay.com/docs/88394/smcj.pdf
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8344
        Bi directional diodes measure open both ways.
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • jshhh
          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
          by jshhh
          Hi guys,
          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
          Anybody know how to remove this type of fuse?
          (The fuse is toward the bottom of the image labeled F2)...
          06-17-2025, 01:35 AM
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
