Capacitor Values: Don't Believe the Label
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    May 1, 2007 12:00 PM
    By Steven M. Sandler, Program Engineer, Acme Aerospace Division and Actuant Co., Tempe, Ariz.
    Power Electronics
    Surprisingly, more often than not, a ceramic capacitor does not exhibit its specified value of capacitance in an actual power-supply application. So the 22-uF capacitor you've selected won't look like 22 uF once its designed into your circuit. The underlying problem is parasitics. These nonideal characteristics are a chronic driver of performance and can be painful to deal with, especially when you don't realize they are impacting your circuit operation. A high-frequency dc-dc converter provides a design example that illustrates the impact of various parasitics on capacitors when modeling the converter's performance in SPICE.
    At this point, we requested and were provided with the manufacturer's capacitor datasheet. It quickly became clear that there was a severe dc-bias effect (Fig. 2). The manufacturer's data indicated that at 1.8 V (the converter's output voltage) the capacitance decreased by 25%, which made the capacitance 16.5 uF.
    PeteS in CA
  • Harvey
    • Apr 2007
    • 264
    Re: Capacitor Values: Don't Believe the Label
    Ceramic capacitors have always had a huge tolerance, its one of the reasons they were never used in critical applications, and something that only circuit simulators struggle to handle.
    But to be honest - if the circuit couldn't stand a 25% reduction in capacitance its time to go back to the drawing board.....
    • rashidjafar
      Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
      by rashidjafar
      I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
      Values for :-
      PC43 : Capacitor [3x1.5mm]
      PL7 : Inductor [2x1mm]
      PC39 : Capacitor [1x0.5mm]
      Any ideas would be appreciated.
      I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
      08-07-2025, 05:10 PM
    • mrkmpn
      Capacitor values in boardview
      by mrkmpn
      I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
      Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
      Is there any way to deteremine if one without infrormation matches one that shows those details?
      05-25-2022, 12:03 PM
    • chth96
      If I replace with inferior capacitor, Is it No harm to other IC components at all?
      by chth96
      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
      I know that these capacitor will not last as long as nichicon capacitor...
      12-22-2023, 04:34 AM
    • chth96
      How can I test non-polarized capacitor?
      by chth96
      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
