Tools and supply reconndations
  • evilkitty
    • Nov 2017
    • 299
    Is this still a/the recommend iron?
    https://www.amazon.com/KSGER-Tempera.../dp/B07PYFSCJ9
    *For use at a desk w/ cheap replacement tips available (if i need to get brand names ones for a specific use that is fine)
    i would like something good for SMD parts on boards (not messing with BGA comments)
    a tip recommendations would be nice
    where should i get some flux and low melt solder from?
    other tool recommendations?
    Other tools i have or ordered:
    ZD-915 de-soldering gun
    Atten ST-862D (our fav. right to repair spokeman has these for $200, they were 230 or 240 last week)
    Could have swore this side had a dark mode... maybe i am being blinded by the UI and can't find it again?
    • 31256
    new owner stole the dark mode to save server use
    if your getting a 915 search my threads about making your own filter discs and adding an extra inline filter.
    also the fan will need to be replaced at some point - thats covered too.
      • Jul 2011
      • 6070
      You should have seen my modification to the ZD-915 type desoldering gun where I used an external switching power supply because the one that is in it is not designed very well and after many hours of use it has a tendency to fail I would highly recommend that you change the cooling fan and change the the resistor connection for the fan so it see 24 volt straight from the power supply instead of around 15 volts or so because they run the hell out of the 12 volt fan now I have one that has a 14 volt fan which is the way it comes originally but I also changed to a 24 volt and it moves more air and is not as noisy
      Here is the post that I made about using an external switching power supply for ZD-987
      https://www.badcaps.net/forum/troubl...g-power-supply
      Apparently this desoldering gun station dose not use a switching power supply interesting but I do not like it price but it has a feature that is interesting however and it can be connected to your computer I am not sure exactly what it suppose to do for you
      ATTEN GT-5150 high-power soldering station 150W high-power intelligent lead-free maintenance system welding station
      https://www.aliexpress.com/i/2255801...apt=4itemAdapt
        • Jul 2011
        • 6070
        You should have seen my modification to the ZD-915 ( proof of concept ) type desoldering gun where I used an external switching power supply because the one that is in it is not designed very well and after many hours of use it has a tendency to fail I would highly recommend that you change the cooling fan and change the the resistor connection for the fan so it see 24 volt straight from the power supply instead of around 15 volts or so because they run the hell out of the 12 volt fan now I have one that has a 14 volt fan which is the way it comes originally but I also changed to a 24 volt and it moves more air and is not as noisy
        I add the “proof of concept” but time had expired for me to do it
        • evilkitty
          • Nov 2017
          • 299
          how poorly does that have to have been implemented for that to be a issue? i find it hard to bevel what should just be a few lines of css a concern
          i was mainly asking for a iron recommendation and any other stuff i really need eg tweezers, flux, low melt solder, stuff i would need to something like replace a power stage/mosfet on a GPU
          for the zd-915 i have new caps to replace the crappy stock ones, making my own filters would be cool, but i have spare parts for it
            • Jul 2011
            • 6070
            If you have an iron from the same company it also has the same switching power issues and the iron it self has an issue after many hours of use either the heating element or the temperature sensor wire fails the tips are decent for the most part
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
