Need help identifying this smd component.
  • gurangax
    • Apr 2020
    • 34
    • Malaysia
    Anyone knows what component is this? seems like a LDO. And where might i buy it? It seems to be shorted. its a 5 pin smd component with marking 12BE
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    May be- Click image for larger version
    • gurangax
      • Apr 2020
      • 34
      • Malaysia
      I did a bit of research and found the most suitable pinouts, but I need to know which voltage the output is. It is placed near the CPU. This is a Chinese Android Karaoke box. The problem is its dead with only charging light. I did replaced some other broken LDOs. This one seems to be shorted ground pin to output with 26ohm. I removed it to check and it is still shorted.
      • gurangax
        • Apr 2020
        • 34
        • Malaysia
        This is the most probable pinouts.
        • gurangax
          • Apr 2020
          • 34
          • Malaysia
          Here is update. The device is revived. I used an adjustable regulator with 1.3v as output. Other things i've done is some ldo replacement and emmc reball as well.
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            Congratulations on solving the problem.
            • gurangax
              • Apr 2020
              • 34
              • Malaysia
              thank you my friend
