Simple current variable circuit
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    At electronic point of view, what circuit is best in performance to control shutdown pin of adjustable voltage regulator, and why?
    • 31255
    those make no sense,
    using a transistor to bypass the ajustment resistors and ground the feedback pin should force the regulator to go full-on.
      • Jul 2011
      • 6070
      The LM317 does not have shut down pin you need to look at something like XL4015 or something like this but if you buy the premade module they do not use this pin for nothing so you would have to solder a wire to that pin so you could control it that way
      If you want to use a LM317 you can buy a kit with all the parts or you can get it assembled module and they are not that expensive and you could add a 5 amp relay with a push button for the on and off switching and if you want to get a little fancy you could add LED light indicator so you would know if the output is on or off will do the same thing but my suggestion is to put the positive and negative output wires to the relay for best results this would be the way I would do it if I was building one
        • 31255
        you could power the regulator input through a fet
        • harp
          • Jun 2022
          • 642
          • Planet Earth
          When adj pin is connect to ground, vreg act that lower output to 1.2v.
          I see I am not be clear in question... regardles to arrangement (orientation, configuration, position) of "sensing transistor", what circuit can best match proper lab power supply?
          This ask because I build something like in picture 3, and it work, but not work like expected, ie, cant setup a small current limmit like 10mA (minimum is 190mA) and affect voltage control.
            • 31255
            none of those circuits monitor the output current.
            you cant monitor the input because it will be effected by losses in the regulator.
            • redwire
              • 3912
              There's two problems with those circuits - sensing the current, and then dialing down the output voltage, to get lower current.
              Best they can do is take the ADJ pin to ground, giving 1.25V output. So you will still get full current below 1.25V !
              A short-circuit or charging 1.2V battery... there is no current limiting at all. Unless you add a -ve voltage rail like -1.3V
              Once I designed a bench power supply and the lowest output voltage it could go to was 0.05V and I set the current-limit to 100mA it was working fine. Tried shorting the output and got over 5A! Took me a while to figure out what was wrong. The current-limit circuit could only dial down output voltage to 0.05V but this was lots of current into shorted leads.
              To sense current using a transistor E-B junction, you need a 0.7V drop across the sense-resistor. This is very lossy and makes heat. It's only a good cheap scheme for outright overload protection. Terrible for variable current-limiting.
                • Jul 2011
                • 6070
                It would help to know exactly what you want to do with this will depend on what circuit you are wanting to do
                I may have the same need as you but I looking for a solution for a 5 volt but the lowest milliampere is 50 but I using for charging very small battery cells that have a low current output but I might just use a LM317 setup in current mode and a on / off switch for the output
                I could use my battery testing machine to charge them for testing but I really do not want to use it for just charging a battery pack this way In the past i have used LM317 regulator in the current mode now for very low current you do not have to use a heat sink
                But if you are planning on using it as a bench power supply I would highly recommend you use a heat sink now if you want to have high current and low current use use a switch to go between high and low because if you do high current you need to use a wire wound pot control if you use a carbon based pot control you will burn it but trust me I have done it before
                For a very long time back in the day before 18650 and 21700 came on the market and the only rechargeable battery cells your only choice was nicad battery cells I had a LM317 setup in the current mode and a resistor and pot control the reason for the resistor was to control the maximum current that the pot control would give you and had another LM317 in voltage mode when I wanted to do fast charging I also made a charger that had voltage and current control but I dismantle this many years ago when 18650 came on the market
                • harp
                  • Jun 2022
                  • 642
                  • Planet Earth
                  Thank you all for information!
                  So, it will work if control current circuit be moved as-is and put between output and divider of LM350 vreg, while feed negative -1.3v on adj pin?
                  Sam, I know what I want, but dont know how to do it, or if possible on simply way. My goal is to add current limmiting circuit on a clasical simple LM350 voltage regulator, seamlessly without complicated circuit, and that work more-less like classic lab psu.
                  The power is not important, max may be 3A for that vreg or less, but the ability to adjust wanted current is crucial, especialy near zero.
                  When I have finished circuit, fine adjustment can be make, like proper spanning section of transistor or so.
                    • Jul 2011
                    • 6070
                    I have try those circuits with the bypass transistor but I was not very impressed with the results that I got from them either because I did use the exactly same parts that were listed or just because I did not have add the fine control pot I am not sure if the LM350 are still available because I have not seen any advertisements for any of them in many years now if you find some please post where you got them from the popular transistor used for the bypass circuit was the 2n305 but I am not sure if they are still available or not either because the last time I saw some available was several years ago
                    I just did a eBay search for a bench power supply and all I see is switching power supply really there are certain things that you should not try to test with a switching power supplies like motors and things like that
                    I have bought a switching bench power supply and I was not really impressed with it because after using it a year or so the voltage was not as stable as it was new and even after recapping it was not much better so I have not bought another one a good thing I have several bench power supples that have real power transformers in them and to me the way I use mine a switching bench power supply would not last
                    I did a google search and found a linear bench power supply but they have really gone up in price since the last time I bought one
                    https://www.parts-express.com/Bencht...904?quantity=1
                    i can see the reason why you want to build one
                    If you are looking for a transformer you can still find them at MPJA electronics store here in Florida or at least the last time I looked which was not that long ago
                      Surface Mount Fuses Fundamentals Datasheet
                      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                      10-07-2024, 06:07 AM
                    • Nevillet
                      Simple PIR sensor circuit to drive a small motor
                      by Nevillet
                      Hi All,
                      I'd like some help designing a simple circuit for driving a small DC motor.
                      The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
                      I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
                      Can somebody design me a simple circuit for me using something like a 2N3904?
                      I'm happy to include a relay if that makes sense.
                      Many thanks.
                      https://www.badcaps.net/forum/attachment.php?attachmentid=3...
                      07-09-2023, 10:48 AM
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                      Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                      by sam_sam_sam
                      I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                      https://www.ebay.com/itm/116497313155?var=416785404161
                      Here are some of the description from the eBay seller
                      The main parameters:
                      1. Product name: High-power non-isolated DC boost module power supply.
                      2. Product model: 100A2000W.
                      3. Input voltage: DC12V-60V.
                      4. Input current: 100A (maximum)....
                      05-18-2025, 09:45 AM
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
