Questions for Fusible Resistors
  • redwire
    • Dec 2010
    • 3910
    Re: Questions for Fusible Resistors
    Uh what resistor, this thread has been about a few different appliances. Best to start a new repair thread about it.
    Last post was 2017. Usually bots do this kind of thing with necro threads...
    • reessi
      20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
      by reessi
      My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
      The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
      The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
      I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
      08-22-2024, 08:12 AM
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • Widget
      Blown heated blanker controller. Trying to figure out these smd resistors
      by Widget
      We have one of those heated throw blankets you plug into AC power. The other day it went *bzzzbzzzbbzz... pop*, so I opened it up to find what appears to be two resistors gone *poof*. (R7 & R14 in picture)
      luckily, we have a second blanker with what appears to be identical controller, so I opened it up to take a picture
      According to the good controller PCB, R7 = 9531, & R14 = 103
      Online SMD resistor calculator says
      R7 - 9531 = 95.3kohm
      R14 - 103 = 10kohm
      Is this correct? Would all I need is a 10k...
      06-30-2024, 11:22 AM
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
    • kahlil88
      Displaced tiny resistors on Dell Dimension 8300 board
      by kahlil88
      Had some difficulty removing the caps off my Dimension 8300 board. My cheap soldering iron just couldn't seem to melt the solder so I flipped over the board and used hot air. They all popped out fine but halfway thru wicking up the remaining solder, I noticed several tiny resistors near the CPU had been bumped out of place! ...
      08-29-2022, 05:46 AM
