Hi I have a philips 42PFP5532D/05 with the fault being the 12V on the power supply board. Does any one know how to fix it and what is the problem? Please if anyone can pin point the problem and let me know
philips 42PFP5532D/05 12V fault
Re: philips 42PFP5532D/05 12V fault
"fault being 12v on power supply ",as in low 12v?,12v missing?,by the way,repost this in tv section for more views.
we also need pics of good quality,or we are working blind.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
by alltvrepairsHi,
715ga018-p01-006-003s
Am trying to find a pdf .
i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
tried with meter most components like resistors diodes etc.
in secondary there are no shorts either.
This was struck by a lightning and could see a burn under the air gap capacitor.
Attaching the board.
Any clues welcome.
Tks... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic...
Channel: Schematics and Boardviews
11-06-2024, 03:47 AM -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... - Loading...
