in standby does the main transformer run? If so does the transformer put out more voltage when the smps is in full operation?
smps transformer
Tags: None
Re: smps transformer
The transformer does not usually run. Big transformers have a minimum magnetising current required to operate properly, which means they are generally inefficient and this would consume too much power. Legal requirement in EU is now less than 0.5W in standby.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
If the power supply is like a computer SMPS, there is kind of a second, smaller power supply that runs the 5V stand by circuit. Its generally a very simple two transistor setup on a cheaper unit, or a discrete IC, that has a low current rating. The 5V stand by circuit has its own, small, transformer.
by learnmoreHello Community,
I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
Peace
LM...11-04-2025, 09:35 AM -
by denistenHi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
04-14-2023, 03:24 AM -
by HounddoghillSharp TV LC-80LE633U
Power supply board DPS 285BP Run TKB096WJQZ
Standby transformer markings (attached picture)
MP-130I(01)
AV-DP11153 Delta
Dcum 1244(03) H6P
So an event in the primary exploded the cap (C7901)on pin one of the Standby circuit IC. So after replacing a couple diodes a the 2.2ohm resistor(fuse) I found the transformer inputs are open.
Anyone know about replacements for this transformer?
I suspect the original is not available.
https://www.badcaps.net/forum/images/smilies/silly.gif
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by BriesmithI have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on... - Loading...
