Anyone have experience with an RC driven temporary "ON" transistor switch?
  • EasyG0ing1
    Enthusiast
    • Jul 2024
    • 9
    The idea is to use a transistor to activate a latching relay once a voltage is applied but to prevent a constant voltage from being applied to the relay coil, I thought it might be a good idea if it were possible to make sure that the voltage applied to the coil is temporary even though the source voltage could be "ON" for long periods of time.
    This is the circuit that I came up with. I have not tested it yet because I don't have the relay yet, though I am looking for anyone who might have experience with this kind of a setup to hopefully offer some advice, words of wisdom, etc.
Name:	Screenshot 2024-07-03 at 8.46.05 AM.png
    Thank you,
    Mike
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    best to add a flyback diode across the relay coil
      • 31214
      is better
      • EasyG0ing1
        Enthusiast
        • Jul 2024
        • 9
        Originally posted by stj
        555
        is better
        You mean it's better to use a 555 instead of the RC circuit? Can you show me an example of this?
        • harp
          • Jun 2022
          • 628
          • Planet Earth
          I think that your R1 must be a way to higher then 1k to C1 have sense. It is paralel with it... But dont know your preferences, what is the time interval for ON state?
          I have some schematics for 555 one shoot, if it ok to your needs.
          • EasyG0ing1
            Enthusiast
            • Jul 2024
            • 9
            555
            is better
            Would you be referring to something like this?
Name:	Screenshot 2024-07-03 at 12.09.05 PM.png
            • EasyG0ing1
              Enthusiast
              • Jul 2024
              • 9
              Well, the idea is that as soon as voltage is applied, the transistor goes into saturation but only for about 1 second ... maybe 2 or anywhere in between, but then after that time, the transistor shuts off even though power is still applied. Also, I calculated the values of R1 and C1 using t = RC where 33k times 47µ = appx 1.55 seconds.
              • harp
                • Jun 2022
                • 628
                • Planet Earth
                Yes, then use only one 555 from circuit... the circuit is trigger by grounding input, and if it stay grounded it maintain only one single initial pulse of 1 second duration.
                • EasyG0ing1
                  Enthusiast
                  • Jul 2024
                  • 9
                  I built this circuit
Name:	Screenshot 2024-07-03 at 6.38.35 PM.png
                  And indeed when I measure across the 10k resistor, I get 5 volts for a short time, and then it goes to 0. However, when I remove power from the circuit altogether, the voltage across the 10k goes close to 5 volts and then slowly dissipates ... it takes about 5 seconds for this to happen. How can I make sure that the 10k stays at 0 volts when I cut power to the circuit?
                  • harp
                    • Jun 2022
                    • 628
                    • Planet Earth
                    I dont know what you mean... accross 10k... on collector (respect to ground) is normally 5V if transistor is not powered on.
                    Are you simulating this circuit, or you actualy built it on testboard?
                    Have you large capacitor on power rail with you try to control circuit?
                    You shall measure between 555 pin#3 and ground.
                    When you designed a new circuit, allways start from basic circuit, and gradualy develop with stable modules, so, get rid of transistor at the moment, and on output connect 470 ohm resistor in series with one LED to ground.
                    See:
                    http://www.fileconvoy.com/dfl.php?id...ce601e3f503beb
                      • 31214
                      https://ohmslawcalculator.com/555-monostable-calculator
                      • truclacicr
                        • Apr 2019
                        • 345
                        • australia
                        The first circuit makes no sense. The transistor's base will never see more than 0.1V, so it will never turn on.
                        You need to interchange the positions of R2 and C1, and insert R1 (plus a 1.8V zener?) into the base rather than between base and ground.​
                          • Jul 2011
                          • 6069
                          Thank for sharing this calculator for the 555 timer ic chip I could have used this a couple of times in the past
                          • EasyG0ing1
                            Enthusiast
                            • Jul 2024
                            • 9
                            I mean I measured voltage across the 10k resistor... negative lead of the volt meter on the collector and positive lead on the other side of the resistor.
                            • EasyG0ing1
                              Enthusiast
                              • Jul 2024
                              • 9
                              See:
                              I built the circuit on a breadboard. Using a bench power supply for power source.
                              The capacitance values are as shown in the schematic, all ceramic capacitors. When I put a load resistor on pin 3 to ground, the circuit works as I described. It goes high for a short time, then it goes to zero volts. However, when I remove power from the circuit, the voltage at pin 3 goes high again and slowly drains down to zero.
                              My suspicion is that because pin 4 is tied to VCC, it leaves pin 3 in an "on" state and whatever is causing it to clamp down to zero after power on is simply no longer holding when power is removed from the circuit. Being able to bring pin 4 to ground at power down would probably stop it, but I don't know how to do that.
                              • petehall347
                                • Jan 2015
                                • 4440
                                • United Kingdom
                                think you need a diode across the 10k much the same as if it was a relay .. but i am often wrong with such things
                                • harp
                                  • Jun 2022
                                  • 628
                                  • Planet Earth
                                  From where? Investigate what is source in this moment?
                                  If you put LED like I say, is it act also like that? Your real load, relay definitely dont do that, there is no power for that.
                                  But I want you to realize that in general electronic control and regulation circuit is not intended to be designed to control (operate) withot power, or in lack of it. 555 pin#4 cant operate correctly without powered ic already. If you have some power on board all the time, that must be using to control circuit, the signals and sense must be apart of that. Maybe to consider redesign circuit?
                                  • harp
                                    • Jun 2022
                                    • 628
                                    • Planet Earth
                                    If transistor is closed (blocked), on collector (one side of resistor) and on positive rail (other side of resistor) you have 5V on both point respect to ground, so, between them there is no difference in potential at all - 0V. Thats why you dont measure voltage accross resistor, in general.
                                      • 31214
                                      use film caps for the timing, ceramics can drift by upto 40% with temperature, film is 5%
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        truclacicr had it correct in post #12.
                                        The first circuit if it were drawn right is (almost) typical of power on reset circuitry, no need for a 555 if all one needs is POR.
                                        Changes as said is to swap the 33K and 47µF capacitor. Lose the 1k resistor, not needed and interferes with operation. Adding a diode with anode to GND and cathode to the base of the transistor will help speed up cycle time.
                                        BTW you can and should test with a LED or light bulb or something before you get the relay, it should pulse once on power up and stay off until you remove and reapply power.
                                        • CuriousJohn
                                          Burco boiler power problem
                                          by CuriousJohn
                                          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                          12-22-2024, 10:25 AM
                                        • SluggerB
                                          Help making a switch work the opposite way with a relay
                                          by SluggerB
                                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                          02-07-2025, 07:57 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
