lithium iron battery pack rebuilding kit
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    changing the boards isnt an option . the lights on the front need to operate and they are on the board along with the switch .
      • Jul 2011
      • 6068
      Originally posted by stj
      I bought one of these about a months ago or so and I had time to test it today I am very impressed with the results of the quality of the tab welding I should have bought one a lot sooner but the real question how long will it last with heavy use this is the question
      It some really nice features one being it monitors the battery voltage and it tells you what current was used when you do a weld you can adjust the
      Preheat time = 03 milliseconds
      Pulse time = 13 millisecond s
      The time when you have the welding tips steady then it fires intermittent time 10 milliseconds
      One function that is marked Dots = 2
      One note the preheat is very important function because I have several different battery operated battery stud welder and they do not have this feature or function and they just fire when you have the probes steady and then fires but the tab welding looks like crap and it does not penetrate the tabbing metal which this one does have this feature and function and you can see the difference in the quality of tab welding
      I use just enough preheat time to see it glow for a fraction of a second then it pluses it and you are done and wait for the next time you hold still the probes
      Plus you do not have to hold the probes that close together to get good results which is also a plus
      • razenxd
        How can I charge that battery pack?
        by razenxd
        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
        Now, I have noticed a few things.
        The "dead" battery, while connected to charger and NOT Charging will...
        12-05-2024, 06:11 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
        by sam_sam_sam
        I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
        I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
        06-18-2023, 05:48 PM
        Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
        by sam_sam_sam
        I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
        I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
        05-26-2024, 10:44 AM
        New project for a Lipo4 based battery pack for a battery backup that I found an enclosure from Battery Hookup
        by sam_sam_sam
        Right now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
        When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
        https://batteryhookup.com/products/3...ttery-with-bms
        These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue...
        09-15-2024, 12:17 PM
