ID smd 6pin chip - GM2 for electric scooter display
  • Ihandyrepair
    • Sep 2017
    • 44
    Hi
    working on a not turning on Wheelspeed WS1 scooter.
    diagnosed - issue is the display/power button
    on the board, with the multimeter I noticed there is a short to ground. as the red wire has 0 ohm to ground.
    with infrared camera, this chip (photo circled) would heat up if I push power button on.
    but I can't find any replacement or online info of this chip.
    on the chip you can see it has a label GM2H, I have another good working display with the same chip but it has label GM2C
    could anyone help me id this chip and guide me to mouse or digikey which chip I should get
    the scooter is 36v
    thanks in advance
  • truclacicr
    • Apr 2019
    • 317
    • australia
    It might help if you could trace the circuit around that IC. At least identify its power and ground pins.
    • harp
      • Jun 2022
      • 604
      • Planet Earth
      BL8032
      • Ihandyrepair
        • Sep 2017
        • 44
        thanks BL8032 seems close to it, pins according to the PDF looks the same, I will try to buy this
        thanks again
        • nick@nickbetcher.com
          • May 2024
          thanks again
          Did you fix the issue?
          Also, how did the issue manifest? Did the headlight and taillight turn on briefly when pressing the power button?
          • Ihandyrepair
            • Sep 2017
            • 44
            Still waiting for the chip
            only able to find through eBay
            hopefully coming end of may
            The symptom before I removed the chip was no power
            press power button would not do anything
            but when I checked with my infrared camera
            the chip would heat up
            that is how I knew it was short to ground
              • May 2024
              Thanks for that info.
              When you're measuring the short to ground, I assume you're measuring it on the header that comes in from the master controller plug, and not at the IC's leads?
              • Ihandyrepair
                • Sep 2017
                • 44
                According to eBay seller the data sheet showed
                pin 1 ground
                pin 3 vin
                I had short here or continuity
                when I removed the chip
                then the short to ground was gone
                before when I test for continuity my wire red and black was 0 ohms
                after removing chip
                it was gone
                checked the chip off board
                pin 1 and 3 shorted
                so I hope that is the issue
                hard to find replacement display for scooter
                I have another gravity blade for repair
                Round display is dim
                can’t see it
                everything seems to work
                but I can’t find another display
