Help identifying this component and its datasheet please
  • Techie_hobby1
    • Feb 2023
    • 64
    • England
    Hi All,
    I believe it to be a TRIAC on TO-252 package, but O might be wrong.
    If anyone can help it would be greatly appreciated
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    May be
    • truclacicr
      • Apr 2019
      • 352
      • australia
      This turned up in a Google search, but the link to the description is now dead:
      https://img.alicdn.com/imgextra/i1/T...0-item_pic.jpg
      Anyway, it was described as "BTB04-1211D 600V 4A Original imported two-way thyristor patch MOS tube TO-252 in stock - Taobao".
      I guess that makes it a TRIAC.
      • Techie_hobby1
        • Feb 2023
        • 64
        • England
        truclacicr yep that is perfect. Thank you. That is the faulty component as well so just got to try and locate a replica
        Many thanks
        • прямо
          TRIAC circuit
          by прямо
          Anyone is familiar with a TRIAC circuit?
          I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
          With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
          Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
          My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
          04-27-2024, 02:12 AM
        • Nevillet
          Identifying a 'FS45' SOT23 device
          by Nevillet
          Hi All,
          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
          Its named FS45 but I can't find a datasheet that seems correct.
          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
          Can anyone identify the device and suggest an alternative?
          Many thanks.
          PS: I have...
          06-19-2024, 11:42 AM
        • SoulFreeze
          Help finding datasheet for component marked G34662
          by SoulFreeze
          Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
          Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
          Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
          05-01-2025, 03:56 AM
        • Rainbow_Chameleon
          Searching Datasheet for AM113 IC by O2MICRO
          by Rainbow_Chameleon
          I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
          Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
          If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
          On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
          So if anyone has a datasheet or at least...
          01-23-2025, 12:03 PM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
