How to replace SMD blue Led with conventional red LED?
  • cap__
    • Oct 2023
    • 13
    "I heard that a blue LED has different voltage values than green and red ones. Green and red ones are easily replaceable, but how do I do that with the blue one?"
    "I have to use the blue one, because green means fully charged and blue means charging."
  • cap__
    • Oct 2023
    • 13
    "A major mistake by buck converter manufacturers: They always "always" forget the solder pads for your own LEDs."
      • 30979
      voltage is not important, your limiting the current.
      so you may want to increase the resistor value a bit - or not, it depends how bright the leds are
        • Jul 2011
        • 6033
        One thing I would add if you are going to use this type of component on a board that has surface mounted parts and you want to use through hole components you can but keep your components leads short as possible and use hot glue to keep them in place and not ripping the components traces from being torn off the board another option is to use very thin wire to the LED and still put some hot glue on the wires to keep them from falling off the board from vibration and breaking loose
        • cap__
          • Oct 2023
          • 13
          Thanks,
          Red smd led = 1,7v
          Green smd led = 1,7v
          Blue smd led = 2,5v
            • 30979
            thats not important - it's the mA required for the brightness you want out of them.
            • CapLeaker
              Leaking Member
              • 8118
              Yeah, look up something like an NSI45020 or NSI45015. LED’s are current controlled not voltage controlled.
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                Well, since you want to have a red LED in place of a blue LED, the answer is simple: you don't need to remove the blue LED at all. Just install the red (or green) LED in parallel to the blue LED. Since red and green LEDs have a lower voltage drop, they will begin to conduct way before the blue LED does. Thus, the blue LED should not light up at all (or it might just barely, but I doubt it would be too visible.)
                In fact, I just helped a family friend's kid with an issue like this last week. He was doing a project for an intro Engineering class and couldn't understand why from the two LEDs he had installed in parallel, only the red one was lighting up properly. He had the proper current limiting resistor and all... but he didn't know that red and green LEDs had different voltage drops, hence why one would light up and the other wouldn't.
                • cap__
                  • Oct 2023
                  • 13
                  Is not that easy
                  The leds have a weird polarity.uPlus and minus are reversed on the second one.
                  Click image for larger version  Name:	wqer2wr23r.jpg Views:	0 Size:	8.2 KB ID:	3259153
                    master hoarder
                    • May 2008
                    • 12170
                    • Bulgaria
                    Doesn't matter. I have a few red (or was it green[?], I forget now) LEDs like that, where the big "cathode" side seen inside through the LED lens is actually the Anode. I just flip those around and they work fine.
                    Or are you dealing with 3-terminal LED's here??
                    • cap__
                      • Oct 2023
                      • 13
ID:	3264797 Quality from China
                        • 30979
                        you need to learn to solder, and pay attention to advice - like using thin flexable wires to prevent that happening.
                          master hoarder
                          • May 2008
                          • 12170
                          • Bulgaria
                          Agreed with stj.
                          I've made that mistake many times in my early years learning electronics repair / soldering.
                          This is the reason I no longer throw away *any* piece of wire away anymore. I have a bin full of scrap wires of all kinds and it always comes in handy at times like this.
                          • cap__
                            • Oct 2023
                            • 13
                            Ok
                              • Jul 2011
                              • 6033
                              Originally posted by cap__
                              Ok
                              Click image for larger version  Name:	20240518_101731.jpg Views:	0 Size:	111.3 KB ID:	3273047
                              Well done one thing I would add is to put a little bit more hot glue on the from the the board top and bottom and little ways down on all the wires together for a strain relief for the wires
                              One miner the thing going on with the diodes would have bent the component leads so that they would hover over the board so you do not have such a long profile
                              • jimjoe123
                                LCD TV Green/Pink screen problem
                                by jimjoe123
                                I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                Then each time...
                                02-23-2020, 01:29 AM
                                Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-07-2024, 05:50 AM
                                Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-07-2024, 05:00 AM
                                Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
