LDO Voltage regulator? E7 AD1 marking
  • AndyBNoobTech
    • Sep 2022
    • 12
    Hi guys, I have a sony soundbar which I am repairing. There is a sot-23-5 component with the markings E7 AD1. I have searched high and low and cannot find anything specific about it. I'm pretty sure it's an LDO voltage regulator, but I have no way of telling what the input and output voltages should be. Does anyone have any insight into what the markings on component relates to?
    Thanks guys
  • truclacicr
    • Apr 2019
    • 352
    • australia
    I found this, but it doesn't look right:
    https://pl.aliexpress.com/item/1005002759685951.html
      ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
      3+1 Voltage Regulator for IMVP-7/VR12 CPUs
      Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
      core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
      configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
      serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
      Based on Intersil's Robust Ripple Regulator...
      11-05-2024, 03:24 PM
    • playit
      diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
      by playit
      hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
      and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
      for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
      02-26-2025, 05:39 AM
    • artvandalai
      Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
      by artvandalai
      This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
      The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
      11-05-2024, 07:38 AM
    • Long AMD
      Acer AL1916W - Two seconds to black - Voltage regulator problem?
      by Long AMD
      Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
      I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
      The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
      09-13-2020, 05:59 PM
    • shakib200
      Ram regulator misbehaving DDR3 VTT voltage Tps 51216
      by shakib200
      The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
      Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
      03-16-2024, 11:33 AM
