Power flex 4 single phase to 3 phase VSD.
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Hi all.
    We've had a drive fail at work. It says it's outputting according to the LCD screen but when tested there's no voltage at all.
    Got it down the workshop for a quick visual but nothing obvious on the caps etc.
    Anyone got any experience with these?
    Thanks.
    • 30979
    must be shit if it doesnt monitor the outputs!
    got any pcb pictures?
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      😂😂 they’re the easiest, simplest, most basic drive you could imagine! 2 wire control with a potentiometer which utilises an output for the common.
      But the advantage they have is that even the simplest of simpletons could figure out how to wire them up.
      I had a go at disassembly earlier and they’re the equivalent of a moulded plug on a domestic appliance. They simply can’t be taken apart for the end user to be able to attempt any sort of repair!
      Thanks for your input though😁
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
        03-31-2024, 02:12 PM
