P21N03REOE4206 Mosfet identification
  • ImpossibleRepairs
    • 27
    Hi guys;
    I need to replace two MOSFET's, the full number is
    P21N03REOE4206; I have attached a Picture; Does anyone maybe know the UM? maybe OUM ? Logo for the manufacturer?
    Please and Many thanks as always;
    • 21968
    Originally posted by ImpossibleRepairs
    Hi guys;
    Please and Many thanks as always;​
    The logo is Excelliance MOS https://www.badcaps.net/forum/troubl...and-datasheets
    • lotas
      • Jan 2016
      • 4805
      • Russia
      EMP21N03HC
      • ImpossibleRepairs
        • 27
        Originally posted by SMDFlea
        thanking you
        • ImpossibleRepairs
          • 27
          Originally posted by lotas
          EMP21N03HC
          Awesome; thanks
          • r12x2
            Mosfet identification on hp pavilion 16-ag0052wm
            by r12x2
            Looking for an exact ID or fully compatible replacement for a dual N‑channel MOSFET used as a synchronous buck pair in a laptop charging stage. The package is the compact ~ 3×3 mm “dual” type where high‑side and low‑side FETs are integrated with a common SW node. The part sits right next to the buck inductor on the charger section. marked as 3840C 35039E. With these thermal pads, it looks like an onsemi NTTFD4D0N04HL or a part from AOS’s AONE family (DFN 3.3×3.3, 8‑pin options such as AONE36132, AONE36182, AONE36196, or AONE38132), but they are not pin‑to‑pin compatible....
            09-25-2025, 04:31 PM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • guizmo1967
            Asus VG278 mosfet identification ?
            by guizmo1967
            My Asus monitor stop working today !! I found the problem on the main board, the power supply board is ok. It's Q9, a mosfet but I have no idea what are the specs since I don't have the schematic for that monitor !!
            Can someone help me identified this mosfet ?
            Thank you !
            04-16-2024, 01:15 PM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
          • bogosort
            Lenovo Slim 7 Pro X - Burned mosfet identification
            by bogosort
            I have a Slim 7 Pro with a burned mosfet. I tried searching online but cannot find anything. (I ended up on the Non-X schematics)
            Please see attached photos.
            It looks like it is written S2EGD on it.
            Thank you!...
            12-30-2023, 01:06 PM
