H5 Zener diode
  • djazeiry
    • Sep 2023
    • 15
    • algeria
    H5 Zener diode
    hello guys ,
    i'm a beginner in electronics and laptop repairs, i had a diode that was blown on my face it's coded as H5 (ZD5245BS2) , i wanna know how come it blown on my face , and secondly is there any equivalent zener diode i that i can replace it with, thank you.
    • 31259
    have to see the circuit to work out why it is blown up
    it's rating is 15v 200mW
    • petehall347
      • Jan 2015
      • 4445
      because you were looking at it when it blown .replace with same or equivalent and expect it to blown again unless you fixed why it blown .
      • djazeiry
        • Sep 2023
        • 15
        • algeria
        thanks a lot for your answer , can i replace it with a another zener diode marked with A5 ?? just to be sure
          • 31259
          probably,
          i mean if it is a zener and not something from a different company using the same code.
          • lcdcaps1
            Usb rechargeable hair clippers blown tp4056 and zener diode
            by lcdcaps1
            Hi
            all
            I have a usb rechargeable hair trimmers that should work plugged in and charge
            it stopped working no led norhing
            I've opened it up and see the tp4056 chip has blown
            There is a zener diode that I tested and get a near short ohms reading no matter which way my leads are
            I don't know what to replace this with
            Please help
            thanks so much...
            03-07-2024, 09:56 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
          • nev1001
            What zener diode might fix the sound on Maestro Mayhem gaming chair?
            by nev1001
            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
            I think an issue could be a zener diode (or capacitor) which has shorted out.
            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
            04-17-2025, 05:09 PM
          • Vincenzo2
            Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
            by Vincenzo2
            My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
            Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
            I put some pictures here to show that it is labeled "M7"....
            09-07-2023, 07:43 PM
