Usb rechargeable hair clippers blown tp4056 and zener diode
  • lcdcaps1
    • Oct 2011
    • 342
    Hi
    all
    I have a usb rechargeable hair trimmers that should work plugged in and charge
    it stopped working no led norhing
    I've opened it up and see the tp4056 chip has blown
    There is a zener diode that I tested and get a near short ohms reading no matter which way my leads are
    I don't know what to replace this with
    Please help
    thanks so much
    • 31717
    a 5v1 zener - 500mW probably,
    it is to protect against a bad psu so check the psu is giving a clean 5v or less.
    maybe upgrade the zener to 5v6 but it doesnt explain the chip unless somebody tried to run the motor while the psu was plugged in
      • 31717
      actually i'm slightly wrong, the zener is to stop the motor spiking the chip,
      so if you can fit one - use a 1w or higher diode
      • lcdcaps1
        • Oct 2011
        • 342
        Thanks for the reply
        When you say a 1w diode
        is that still a 5v1
        • petehall347
          • Jan 2015
          • 4480
          did you test the diode on the board ? if so either remove it to test or disconnect the motor
          • lcdcaps1
            • Oct 2011
            • 342
            Yes I tested the diode it was a showing low ohms reading both ways
              • 31717
              if you left the motor connected you will be seing the motor windings.
              desolder the motor wires.
              did you use this while it was charging btw?
              i'v never seen a tp4056 cooked like that!
              maybe the battery needs to be checked!
              • lcdcaps1
                • Oct 2011
                • 342
                I will do that
                does that mean the Zener diode would still be ok
                After speaking to the person who gave this to me, to look at
                They said they plugged in another cable that had the same connector but the power adapter was different
                was not usb
                I believe that this is why the TP4056 blew
                I I replace the TP4056 and deal with the burn damage
                will it work again or should I replace the zener diode as well with a higher one
                • lcdcaps1
                  • Oct 2011
                  • 342
                  Can I use
                  1N4734A
                  5v6 1w
                  instead of smd
                    • 31717
                    if it fits,
                    make sure there is room to put the case together over it
                    but the original may be good still
                    • lcdcaps1
                      • Oct 2011
                      • 342
                      if it fits,
                      Is there any way to know if the Zenner diode is ok without removing it
                      • lcdcaps1
                        • Oct 2011
                        • 342
                        You were right
                        I got 1.6 ohms across the motor terminals and
                        i got 1.7 ohms across the diode both ways
                        i got 0.002 v drop both ways
                        • petehall347
                          • Jan 2015
                          • 4480
                          did you disconnect the motor yet ?
                          • lcdcaps1
                            • Oct 2011
                            • 342
                            In the process of doing it
                            • lcdcaps1
                              • Oct 2011
                              • 342
                              I am thinking that should i replace with a new better zenner diode as I am replacing the chip
                              • lcdcaps1
                                • Oct 2011
                                • 342
                                Would it be better to replace it with a 5v1 diode or a 5v6 diode, please
                                i think the glass might be cracked
                                  • 31717
                                  you could use 5v1,
                                  normally you wouldnt use a zener across a motor so i dont know why it's there.
                                  you would use a 1N4007 rectifier
                                  • petehall347
                                    • Jan 2015
                                    • 4480
                                    maybe using it to regulate motor speed ?
                                    • lcdcaps1
                                      • Oct 2011
                                      • 342
                                      I can replqce with a 5v1 zener diode smd which is 0.5 w
                                      or 5v1 zener diode 1w which is through hole
                                      I'm thinking if I replace with the 1w zenner diode it will add a bit more protection
                                      any thoughts please
                                        • 31717
                                        a 1w will take more stress before failing - if it even did fail
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
