Lcd power supply questions..
  • a_eclipse_guy
    • Apr 2013
    • 8
    What I would like to do is reuse an old computer lcd screen for a project.
    What I would like to do it power up the backlight only with only 12V going to it.
    Anyone have any ideas on how to do this? I do not have anything left from the old monitor except the frame,the tubes and the plexiglass part of the screen.
    I am thinking I would need something like a ballast for your fluorescent lights.
    Any ideas?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Lcd power supply questions..
    http://www.ebay.co.uk/itm/Ultra-MINI...item3382facb6e
    deping how many tubes it has there is a two tube version as well
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
