KA7808 Voltage Regulator
  • dj_ricoh
    • 2073
    • uk
    hy guys
    still learning, so stupid Q incoming
    i got this crap *&&%&* cd player i wanna fix(won`t power) and PSu i think its ok.
    i just try to find thinks that i don`t know and i wanna know how it works.
    So, i put this regulator on the PSU and see how it outputs
    everything its ok until i pass 8V, i get stuck on 7.85V
    ups sry for the side pics
    Re: KA7808 Voltage Regulator
    That would appear to be working, it is an 8V device.
    • dj_ricoh
      • 2073
      • uk
      ty tom
      Back to testing crap caps
        Crap caps would be unexpected, and would probably only cause poor audio quality, digital skipping, etc. Does CD player have a track number display? If so, focus on the controller chip for that (probably surface mount, bottom of board) -- if you can find a datasheet for it, check the VDD etc supply voltages.
        • mariushm
          • May 2011
          • 3799
          The 7808 is a linear regulator.
          Like any linear regulator, it has a specific voltage drop. In the 78xx family this voltage drop is 2v, but it can be slightly less if there's nothing connected at the output or something that uses very little power (like a led for example).
          So if you want to make sure it works fine and outputs 8v, you need to give an input voltage of at least 10v. If you give it less than 10v, it will output Vin - ~ 2v.
          So you got 7.85v - this is a bit outside the tolerance, a bit far away from 8v. But, I don't know what input voltage you used. Ah nevermind, I see 15.4v on the power supply. It's a bit low to see 7.85v but I wouldn't consider the regulator bad right away.
            7.85V is within 2%, regulator like that is typically 5% tolerance.
            • PeteS in CA
              • Aug 2005
              • 3576
              • USA, Unsure of Planet
              One convenient thing about the part numbering of uA78xx and uA79xx type parts (and LM340-xx and LM320-xx parts) is that the "xx" is the output voltage. How +8V and -8V came to be standard voltages (and for what), I don't know.
              PeteS in CA
                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                Based on Intersil's Robust Ripple Regulator...
                11-05-2024, 03:24 PM
              • playit
                diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                by playit
                hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                02-26-2025, 05:39 AM
              • artvandalai
                Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                by artvandalai
                This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                11-05-2024, 07:38 AM
              • Long AMD
                Acer AL1916W - Two seconds to black - Voltage regulator problem?
                by Long AMD
                Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
                I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
                The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
                09-13-2020, 05:59 PM
              • shakib200
                Ram regulator misbehaving DDR3 VTT voltage Tps 51216
                by shakib200
                The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
                Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
                03-16-2024, 11:33 AM
