DC to DC converter? component identification
  • MuertoGB
    • Sep 2021
    • 94
    • United Kingdom
    I've a SOT23-6 (i think LDO) that is glowing like a Christmas tree on the thermal camera. Pretty sure it takes 5V USB C VIN on pin 4, I'm not sure what it outputs. I've marked the pins and what they do, or what resistor they're connected to. Marking is JWE2J (Joulwatt). The component is on the main board of a Razer Kiyo Pro webcam. I think the ??? pin is EN. Thanks for any help in advance.
    Click image for larger version  Name:	20231221_004004.png Views:	0 Size:	6.14 MB ID:	3166255
  • truclacicr
    • Apr 2019
    • 300
    • australia
    https://monitor.net.ru/forum/smd-components/terms/1379
    JWE2* = JW5052S
    https://datasheet.lcsc.com/lcsc/2006...2S_C324578.pdf
    • MuertoGB
      • Sep 2021
      • 94
      • United Kingdom
      Good work, thank you very much for helping. I'll get some on order.
      • truclacicr
        • Apr 2019
        • 300
        • australia
        The pinout doesn't match your findings ...
        • MuertoGB
          • Sep 2021
          • 94
          • United Kingdom
          I have double checked, and my pinout was correct. Here is a picture of the IC in situ.
Name:	20231222_034313 - Copy.jpg
          • harp
            • Jun 2022
            • 598
            • Planet Earth
            Is output shorted? Sometimes low resistance on output can make ldo ic to glow...
            • MuertoGB
              MuertoGB commented
              Editing a comment
              No, I checked after removing the IC and nothing is shorted anymore.
          • truclacicr
            • Apr 2019
            • 300
            • australia
            If that is an inductor on pin #3, then the IC cannot be an LDO, it must be a switchmode converter. The output would be the lower end of the inductor. Check the resistance to ground at this point.
            I suspect that this IC has a similar pinout:
            https://www.ti.com/lit/gpn/TLV62569
            • MuertoGB
              • Sep 2021
              • 94
              • United Kingdom
              Yes, it is an inductor. I've noticed it matches the pinout of the JW5222, looking at the datasheet it could be plausable for a replacement.
              https://datasheet.lcsc.com/lcsc/1912...22_C371424.pdf
              • truclacicr
                • Apr 2019
                • 300
                • australia
                Make sure that the feedback voltage and switching frequency are the same.
                • MuertoGB
                  • Sep 2021
                  • 94
                  • United Kingdom
                  Thanks for all your help. I'll update on how it goes.
                  • bumper1
                    Razer Blade 15 RZ09-0328 DA550-MB - resistor identification
                    by bumper1
                    I have Razer Blade 15 RZ09-0328 MOBO: DA550-MB MP V4.0 20200227 with liquid damage.
                    I need to know value of resistor on photo. Thanks for help. ...
                    07-10-2025, 03:34 AM
                  • bushmann
                    Identification part Razer RZ09-0301
                    by bushmann
                    Please can you help me with identification part on the photo.
                    May be, Power-Distribution Switche with Soft Start but I don`t know.
                    Part is from notebook Razer RZ09-0301 .
                    pinout .
                    1-2 - input 3.3V
                    3 - Enable 3.3V
                    4 - VCC 5V
                    5 - GND
                    6 - capacitor to GND
                    7-8 - output 3.3V for EDP LCD, but no working
                    IF I connect input and output, LCD work fine .
                    Thanks....
                    06-18-2021, 07:50 AM
                    MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                    10-23-2024, 03:23 AM
                  • gizmo1990
                    What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                    by gizmo1990
                    I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                    The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                    10-21-2024, 08:02 AM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
