Help me with 65992d chip datasheet
  • trepachka
    • Oct 2022
    • 456
    I am working on this HP Envy 17-chxxxx laptop. When power button is pressed, I brieftly get 5v and 3.3v lines. While testing components, I checked 65992d chip. Pin#4 appears to be shorted (4th pin down on the left side). When applying 0.8v to it, the chip lights up on the IR camera. I am trying to figure out the chip schematics but it's not available online. Because I do not have another board to compare with, I don't know whether this is normal or not. Click image for larger version
    Perhaps, someone has it?
  • trepachka
    • Oct 2022
    • 456
    Thank you for the late response. Indeed, shorted #4 pin was bad news. I replaced the chip and the laptop powered on.
    • nuri05
      • Dec 2020
      • 5
      • Türkiye
      IN THIS
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • Troystain
        Help EZP2023+ updated chip database for w25q256jveq?
        by Troystain
        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
        I need to add w25q256jveq chip but I do not know what data should I type.
        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
        11-25-2024, 12:53 AM
        Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
        H8S Family / H8S/2100 Series
        Ordering codes:
        F2112TE25V F2112BG25V F2112LP25V
        The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
        CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
        As peripheral functions, each LSI of the group includes a serial communication...
        10-23-2024, 02:33 AM
