hairdryer on electronics
This topic has been answered.
  • tony359
    • Oct 2018
    • 264
    Potential silly question for the community.
    I often use hot air to diagnose components, as they often revive/die with heat/cold. I use my hot air station and freeze spray.
    I was asked whether I could use a hairdryer to warm up PCBs. Obviously you won't have the ability to direct the heat to a specific component but what about ESD? Is it safe to use a hairdryer on an electronic board?
    Thanks!
  • Answer selected by tony359 at 12-15-2023, 03:37 AM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    It’s like watering a garden with a fire hose. Possible, yes. A good way of doing it? Probably not.
    • petehall347
      • Jan 2015
      • 4444
      never heard of it causing a problem .
      • redwire
        • Dec 2010
        • 3912
        Violent airflow through a plastic hose or nozzle or across a PCB will generate a static charge. It's miniscule- but not the case if it is charging up something big as a capacitor and there is no leakage path. Like a person.
        This was known a long time ago with techs vacuum cleaning or using compressed air to clean equipment, there were ESD-related failures. Then 3M came out with special vacs using dissipative plastics.
        If you don't touch (discharge) the nozzle/hose to yourself or the gear I think it's not a problem on an ESD mat, and stay grounded.
        You can also watch a multimeter DCV reading with air blowing across one probe in contact with large metal - PC board etc., other probe earth-grounded. As a primitive electrometer.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8340
          Personally I use both and never had any trouble. But then I don’t use the hair dryer to fault find as such on a naked board. The nozzle is just to big to fault find anything with. I just use it to warm something up maybe or to get a PSU going in a pinch if the starter cap has failed.
          My Weller hot air is running circles around a hair dryer for fault finding.
          • tony359
            • Oct 2018
            • 264
            Thank you!
            Yes, it's not the best way but I have been asked if I would recommend it for a wider audience, that might not have a hot air station. I just wanted to make sure I wasn't going to recommend bad things, that's all! The purpose of the hairdryer is just a quick a dirty way to see if the board starts working again when warmed up.
            Thank you all!
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8340
              • VoicesFYC
                • Apr 2021
                • 26
                the Official Answer ... is YES...You Can and sometimes with a varable temp hairdryer you can find the temp issue faster Daniel.
                • PeteS in CA
                  • Aug 2005
                  • 3582
                  • USA, Unsure of Planet
                  The problem with a heat gun or hair dryer and with freeze spray is that it affects a large area. With freeze spray I soak the tip of a cotton swab with it and then touch the suspect component with the cotton swab tip. Doing something similar with a heat gun is a bit more difficult, and if your probe is metallic, you need to avoid shorting to something.
                  PeteS in CA
                  • tony359
                    • Oct 2018
                    • 264
                    I use the plastic tube of my air dust can (used upside down). With that I can precisely freeze one component if I gently press on the trigger and prevent splashing all around.
                    See my own video here: https://youtu.be/AL64ADVLlJc?t=740 (it should take you to where I freeze a tantalum cap).
                    Heat gun or hairdryer is difficult of course.
                    • Hypersapien
                      Artist seeking to tinker with electronics safely
                      by Hypersapien
                      Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
                      When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
                      10-22-2023, 01:31 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                      Securing a good thermal interface between...
                      10-07-2024, 04:35 AM
                    • proton32064
                      General Question- Electronics from 70's and 80's
                      by proton32064
                      I have a question since I am new here and I don't know if this is the right forum to ask these questions or if I am wasting your time.
                      I am 67 and have a lot of Radios and Electronics I grew up with which puts a lot of them at 50 years or older.
                      A lot of the capacitors are obviously bad but this is my problem.
                      An example would be the Panasonic RC-7469 Clock Radio and the Panasonic RF-888 Radio.
                      I have others like a Canon L-162 Nixie Desktop Calculator 110AC, etc.
                      I have the Service Manuals to some of these and other electronics I have and grew up with and...
                      05-09-2025, 05:16 PM
                    • Galindrada
                      Electronics Books
                      by Galindrada
                      Good evening team,
                      I've been trying to learn electronics since the beggining of the year. My main goal is to fix broken consoles/laptops. It has been a very fullfilling journey and fortunately I've found my way around and I've already fixed a few of them.
                      While there's a lot of info online (this forum as an example) I would like to gather a few suggestions about books on electronics. I've already attempted to read a few ones, but to be honest I haven't found anyone that suits what I'm looking for. As an example "The Art of Electronics" is amazing, but there's...
                      11-27-2023, 05:16 PM
