What are these?
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    What are these?
    I found these on a local auction site: http://www.osta.ee/mingid-plokid-40083062.html
    What are these? Are they worth the 12 euros? About 15 dollars or so.
    I can put text here?!
  • dj_ricoh
    • 2073
    Re: What are these?
    i think they ar tv/sat signal switch like this one http://i00.i.aliimg.com/wsphoto/v0/6...Sat-font-b.jpg
    signal booster maybe
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Re: What are these?
      I thought so. What are they worth?
      • dj_ricoh
        • 2073
        Re: What are these?
        if your business is to make exchanges you will get because it is very cheap.
        those type of products are cheap because you purcase them once not every year .
        i hope it helps what i said :-s
        • DJduck
          • Dec 2012
          • 229
          • Estonia
          Re: What are these?
          Alright, got it, thanks!
          • DJduck
            • Dec 2012
            • 229
            • Estonia
            Re: What are these?
            Is there anything good inside them?
            • Sparks88
              • Sep 2011
              • 110
              Re: What are these?
              these are various power supplies, condition of 2 unknown
              • Crystaleyes
                Fluke 9010A - What are they worth?
                by Crystaleyes
                Hi all.
                I've been offered an old Fluke 9010A Microsystems controller with three pods, but the only question is what is a fair price to pay for it?
                Neither I nor the owner have any idea as to the value, only that they aren't cheap...
                It has been sitting in a warehouse for maybe twenty years, wrapped in plastic, so I would imagine that it would need a recap at least, but maybe not?
                Anyway... I was thinking of offering him about 300 Euros/Dollars, which I think he may accept, considering it will just sit on a shelf for another twenty years otherwise....
                12-18-2022, 06:45 PM
              • brkie
                Samsung UE75TU6905 reboot loop
                by brkie
                I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                I read on Samsung's website (reviews)...
                09-04-2024, 01:45 AM
              • 90Ninety
                43PUS6401/12 PHILIPS 715G7350-P01-000-002S
                by 90Ninety
                So I stupidly volunteered to fix a friend's TV, a Phillips 43PUS6401/12
                I have previously fixed TV's before , even replacing cathode rays , not a fun task .. Typically the advent of subpar capacitors inside the early Samsung Flatscreens is the reason I originally registered here
                However I digress , the Phillps TV was not switching on , no standby light nothing... So rightly or wrongly ( probably wrong ) I assumed the power board was dead , or a faulty power board .. Upon first inspection, I got the MultiBeeper on it , since I am aware of Ohms law , I checked the regular...
                02-07-2024, 08:38 PM
              • valerio_vanni
                Choosing programmer
                by valerio_vanni
                https://www.badcaps.net/forum/troubl...10#post3764310
                I come from this thread (I have to flash a SOIC-8 chip, possibly with a clamp).
                I began searching for a CH341A, since it has low price and it's an operation that is not going to be frequent.
                But during my search I discovered that there's often an issue with voltage, that is 5V instead of 3.3. Someone says to look at PCB colors, some other that it doesn't matter....
                Yesterday, 05:43 PM
              • EasyGoing1
                Soldering Bliss...
                by EasyGoing1
                So i've mentioned that I have this Weller WE1010 that I bought a couple years ago or right soon after they first came out. What I didn't like about it was that I left it on for almost a full 24 hours once so I installed an arduino controlled relay that was programmed to cut power at 45 minutes ... then I didn't like that it didn't have a backlight ... i work in dark-ish conditions quite a bit when im messin with this stuff so I made a solid effort to install a backlight and I actually kind of succeeded ... the iron still works but some of the segments on the display stopped working ... so i figured...
                04-15-2021, 08:27 AM
