Exploded transistor. Can anyone suggest replacement?
  • pnb
    • Apr 2013
    • 41
    This time I am trying to repair the power supply to a vacuum fluorescent display in an instrument cluster.
    Apart from heavy heat damage and a completely wobbly resistor there is a transistor that has exploded.
    Seems to have markings of D 18*5, maybe D1815 and below that S (or 5) in left corner and maybe a 64 or 614 in lower right corner.
    This is a 17 year old part and I cannot seem to find a replacement for a D1815 anything, if that is what it is.
    Can any of the knowledgeable posters on here suggest a replacement transistor i could use? As a Noob I dont even know where to begin a comparison. This is for a vehicle so is 12v any help?
    Re: Exploded transistor. Can anyone suggest replacement?
    Japanese products? 2SD1815 (NPN)?
    https://cdn.badcaps-static.com/pdfs/...51309aa0b9.pdf
    • pnb
      • Apr 2013
      • 41
      Heres the circuit. Seems a little under-engineered to me, almost every joint is bad.
        It looks like Osciallator circuit. You can also see lots of cracked solder joints on the component's legs which is typical failure mode of Japanese made products, you can see that the solder joints are not nice and shiny. I would re-solder all the joints. It looks pretty easy to draw up the circuit.
        • pnb
          • Apr 2013
          • 41
          budm,
          Phoned up my local Jaycar and they dont have 2SB1215 or 2SD1815 available either. None on ebay.
          I would have thought google could turn up a list of compatible parts, but no luck.
          Could be an oscillator circuit, although I dont know how you can tell that. Seems VFD are driven by high frequency pulses..
          http://hem.passagen.se/communication/vfd.html
          • rievax_60
            • May 2012
            • 897
            • australia
            2SD1815 can be found on Aliexpress. The minimum order quantities make it expensive though.
            • pnb
              • Apr 2013
              • 41
              I found one for around $40 including shipping from OS, but that just seems like "F.O.P". Surely there most be something compatible available locally for under $5?
              Any thoughts on the chance of success on scratching around on Gumtree for a free unwanted VCR etc and the likelihood of that being a common part in vfd display drivers?
              What about this D1815 TO252 ? Is that compatible with that suffix?
              http://www.idevopen.com/index.php?ma...ducts_id=14734
              Has anyone used http://www.idevopen.com for parts before? is it a legit operation?
              <<<< edit - scratch above. Looks to me like a TO252 only has two legs. Cant be compatible.
              • rievax_60
                • May 2012
                • 897
                • australia
                The TO252 is a package type with short pins, google it.
                You could try a BD139. If nothing else is wrong after the cracked solder joints are resoldered, I would expect the oscillator to start but likely to not run efficiently.
                The BD139 is likely to get hot.
                Its also possible that the high fault current has damaged the transformer.
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  There are some 2SD1815 on eBay also.
                  • pnb
                    • Apr 2013
                    • 41
                    Ok, Think I found some of those locally at X-on... Ebay OS shipping is a rip off and long wait to boot so I was hoping for a local source..
                    http://www.x-on.com.au/InventoryDeta...uct=2SD1815T-E
                    Not sure what the extra letters mean though, so I guess I will go ahead and get one of those and try it out.
                    • pnb
                      • Apr 2013
                      • 41
                      Thanks for the help everyone!
                      Will post update when project completed.
                        http://www.mouser.com/ProductDetail/...JKbl9w8Vfdc%3d
                        http://www.onsemi.com/PowerSolutions....do?id=2SD1815
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          I have found stuff for good prices at X-on including capacitors. Have to search deep and be prepared to buy many sometimes.
                          I think the postage was 15 or 16 dollars.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            You can also just get replacement transistor of a different part number, as long as it has the right specs! It might be hard to find the right replacement part number though.
                            Muh-soggy-knee
                              Here is the diagram based on the pictures, resistor color may not be correct to the colors I can see on the pictures so the values should be verified.
                              • pnb
                                • Apr 2013
                                • 41
                                Thanks for the help everyone, the 2SD1815 arrived and is the correct replacement part.
                                I re-soldered all cracked joints and tested that all resistors were close to spec. Tested diodes, but did not bother testing the small caps, and did not know how to test the 9-leg transformer so just hoped it was still ok..
                                Re-soldered the main resistor in as far from the board as possible to give it more opportunity to shed heat, and drilled a few small holes in the metal cover for a bit of airflow.
                                The micro-board DC->AC oscillator has been re-soldered onto the cluster and hey presto - the VFD is fluorescing.
                                Really chuffed I got this working again after reading that these VFD's fade out and need to be fed higher voltages close to EOL, all it turned out the be in this case was the AC power supply.
                                Again, thanks for all the contributions.
                                • Haaheim
                                  Bias matching replacement transistor - Parasound 2250
                                  by Haaheim
                                  Hi guys!
                                  I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
                                  According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
                                  05-13-2022, 12:45 PM
                                • the_rem
                                  Unknown transformer : how to find a good replacement part ?
                                  by the_rem
                                  Hello guys,
                                  I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                  I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                  04-23-2025, 01:48 AM
                                • ezenia
                                  PS4 controller left stick potentiometer replacement issue
                                  by ezenia
                                  Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                  So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                  I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                  09-30-2023, 02:19 PM
                                • boosti45
                                  Macbook pro logic board replacement parts quesion
                                  by boosti45
                                  i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                  08-21-2024, 05:23 AM
                                • RickyZA
                                  Help choosing replacement SMD transistor
                                  by RickyZA
                                  Hi there everyone,
                                  Im looking for a replacement transistor for my TV's logic board, unfortunately i had a newbie slip and shorted out the Pwr_On to the 20v rail with the mainboard connected, not very clever at all i know. Here is the damage.
                                  Transistor Close up
                                  Original Transistor Datasheet : RT1P141C Marked P1
                                  Main Board Schematic for transistor Reference: Service Manual / Main board Schematic Not the exact same model but im pretty sure they use the same transistors marked P1 which is the RT1P141C.
                                  My other question is...
                                  06-30-2017, 01:46 PM
