LED lights switch assembly, suggestions needed
  • SaleB
    • Oct 2012
    • 19
    • SER
    A few months ago I wanted to make a dimmable constant current led driver and ask about it in this thread.
    In the mean time I bought a 2.2Amp driver from Meanwell with external dimming option. The LEDs use 42V supply and the driver supplies 42V. Output current is dimmable with external pot, pwm or 0-10v voltage.
    I have opted for pot, and made another circuit that has six switches for six differnt lights, and six bi-color leds that show state of every lamp. Led supply voltage is sunken by a 1W resistor for every led to about 2V, and there lies a new problem. The circuit works fine for last four months, but resistor temperatures give me an uneasy feeling. I get about 90 deg C on all the resistors and now I would like a suggestion for ver. 2 of the same circuit.
    The only solution that I came to is to find a voltage stabilizer that accepts 42V on high side and to add separate lines for led supply with smaller resistors that are applicable for approx 3v sinking. Then to add a massive heat sink to the stabilizer.
    Option B:
    I am thinking about remodeling it all. I have an Arduino dev board and I have made some simple programs with it. I am thinking about making an Arduino based control circuit. Advantage of it would be, to enable it for house automation, for a situation when I master the use of ethernet shield, so I can control all of the functions from local web location.
    In that case, I could use a pwm output for dimming control. But, there rise many other questions about how to connect hardware for other controls and how to power it all. There are six 12W led downlights with intended on/off functions. The driver is powered by one AC line with a switch on a wall. There are also four fluorescent lamps that are now connected to second AC line with second switch on the wall.
    Best scenario that I came to is to connect power for the Arduino board to one AC line, and all the light sources to the other AC line. Now I would need to isolate the AC switching functions from the Arduino. Is this task better served with an optical insulator (optocoupler) and a FET or is it better to use a mechanical relay with some transistor as Arduino output signal amplifier?
    There will I need four output circuits for fluorescent AC lamps, one for AC of the led driver, six for the individual LED lamps, one PWM and a four for multiplexed inputs from 13 switches. Here is another question, can I use multiplex for outputs in the same way I can use it for inputs? What would be a good 16/4 or 8/3 multiplex ic for this use? I am thinking about multiplexers because I think that I get out of free i/o lines.
    Should I add some protection elements (fuses) in the circuit and where? On AC input to Arduino power supply should be a fuse, right? What about dc lines, should I plan protection there too?
    I would like to hear your suggestions on my ideas.
    Thank you all for your time and sorry for a longer post, I tried to be as detailed as possible.
    Regards,
    Sasa
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: LED lights switch assembly, suggestions needed
    90C is okay for a resistor. The high power ones normally run very hot.
    Muh-soggy-knee
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
    • SluggerB
      Help making a switch work the opposite way with a relay
      by SluggerB
      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
      02-07-2025, 07:57 PM
      Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
      Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
      ( needs more cam circuits for the machine to work correctly again )
      https://www.ebay.com/itm/275321870186
      To
      3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
      ( not 4 positions but the right amount of cams circuits )
      https://www.ebay.com/itm/274660439950
      I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
      03-18-2023, 05:12 PM
