SMD Markings
  • askeesick
    • Apr 2013
    SMD Markings
    Is anyone familiar with marking on surface mount diode?
    I have two:
    J3H
    F4J
    They both are about 2.67 mm x 1.62mm.
  • Duncanbest
    • Jul 2012
    • 81
    • Taiwan
    Re: SMD Markings
    maybe
    http://www.alldatasheet.com/view.jsp...word=MMSZ5248B
    • askeesick
      • Apr 2013
      Re: SMD Markings
      thanks
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • Crystaleyes
        Samsung BN44-00259A standby question
        by Crystaleyes
        Hi all.
        I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
        SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
        Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
        The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
        08-11-2023, 05:15 AM
      • tomy78
        Need Information IC marking FMN 930
        by tomy78
        need this IC information. marking FMN 930
        10-20-2025, 06:53 AM
      • dutchgaucho
        Please help to identify component with marking eHFFH
        by dutchgaucho
        Dear BadCaps colleagues,
        I'm working on a HP Omen 16-WF0894ND. Won't turn on. Battery is charging and 3 and 5V rails are present.
        However, I located PU1801 that's only outputting 0.37v as soon as the power button is pressed. Weird voltage imo, although there's no short after the coil. Chip aint getting hot either. Since no diagram is available, I can't really determine what this rail is for, but I assume it might be a PCH PWR rail. Please help me to identify:
        Chip marking eHFFH
        Board model: LA-M783P
        Please also see pictures attached.
        08-28-2025, 02:41 AM
      • Barttech Computers
        hi all need help with IC marking is XA2LD Sot-23-5
        by Barttech Computers
        I'm trying to identify a small SOT-package IC marked "XA2LD" located near the 5V_FS rail on a logic board. The silkscreen shows it as U26/U25, and it's adjacent to components labeled R415, C232, L28, etc.
        Here’s what I know so far:
        • The IC marking is XA2LD (possibly custom or abbreviated).
        • It’s likely involved in power switching or regulation (possibly a load switch or LDO).
        • The package appears to be SOT-23-5 or similar.
        07-27-2025, 09:27 PM
