I said i'll never try reballing...
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: I said i'll never try reballing...
    Originally posted by ravenns
    Yesturday I found a website which is selling this:
    http://uk.farnell.com/itw-chemtronic...-bga/dp/892087
    Is it good for cleaning?
    I've not used it but I expect it should be, Farnell are a good company. And it says it's for BGA, too.
    -David VanHorn
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Thanks guys!
      Very helpful!
      Regarding my hommade machine... I use 2 temperature probes, and get even heat during preheat. When I apply above heating with my hot air station with a nozzle on it, I get slightly different temperatures on those two probes (~5*C). A few days ago I thought I should buy 2 more instruments, so I can cover all four spots around the chip.
      I don't think you need 2 more probes. I use just 2 myself, one on the bottom under the core, and one on the top, on the side of the chip. I've lifted a bunch of chips cleanly with this arrangement. What will help tho, is getting one of those thin thermocouples that go slightly under the chip. Omega thermocouples i think they're called. I have another system in my mind, but i'll keep my mouth shut until i've tried it myself.
      A few months ago I bought a Kingbo flux, and couldn't beleive how easy it is to work with it. Before Kingbo, I used Chinese Amtec (fake), and all it did is damage...
      I have that, and it seems to work alright for me. You just have to remember to clean it afterwards if you used too much, otherwise it can mess up high-speed signals.
      Tryed liquid flux from Check republic or Poland (don't know exactly) it did some good lifting, but Kingbo is THE KING!
      It's from Poland i think, i have some of that too. I tend to use it for other things tho, like SMD rework. It's got too much isopropyl alcohol in it, and bubbles a lot. The advantage is that it's (supposedly) no-clean. The disadvantage is that it leaves this sticky residue all over and you have to clean it anyway.
      A working TV? How boring!
      • ravenns
        • Mar 2013
        • 5
        • Serbia
        I use 2 probes on opposite sides of the chip. I've never used probes ON chip.
        Also, I used to cover chip with capton tape, but all it did is that the SMT components were lifted during heating... (I'm talking about SMT ON the chip)
        I will try to use aluminum foil tape to cover whole chip in order not to cause crack of the chip (mirrored square). Sometimes I get little balls of solder over chip, which I guess is from second leyer of the chip (beneath the chip itself). I'm talking about solder balls which are inside of the chip. This happen rarly, and it happened in my first attempts with high temperatures...
        Now, I'm affraid that using of hot air station will cause breakage of the chip? I use ZD-939 hot air station with BGA nozzle which doesn't have any net for proper disipation of hot air, but it has (I guess) zones - center zone which is the hottest, and the other zone away from the center which is less hot... And now I'm a little unsecure about this center zone will overheat the center of the chip. I hope You understand what I'm trying to say...
        Does anyone use hot air station for reballing?
        Do You think it's a good idea to cover the whole chip with aluminum foil tape?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Are both of your probes on the top? If so, try moving one to the bottom of the board, and do your best to keep both temperatures equal.
          There's no reason to do that.
          It means you got the chip too hot, or you heated it up too fast.
          You can try with a temperature probe and see if you got any hotspots. All i can say is that i'm using exactly the same station and so far so good. I've done many reflows in the past couple years and had only one chip die, and that's the nVidia 8400 in the DV9000 i bought a few weeks ago, which i posted about in this thread.
          I've used exactly the same technique and temperatures with a couple other chips since. I've done a nForce NB in an Acer 5520G and it came back to life. Also an Intel NB/IGP in a Fujitsu E8410, which behaves exactly the same after reflowing (doesn't work unless i press slightly on the NB, in which case it works just fine), but the Fujitsu had obvious water damage, some of it right on the NB heatsink, so the NB is most likely corroded and requires replacement. I've ordered it already.
          So with my DV9000, i think it was just a dud GPU. And i think that's what's in the mail today... I'll go pick it up and come back with news.
          No. As a matter of fact i hardly use it at all, only when there's connectors close to the chip i'm reflowing, so i don't melt them.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5086
            • New Zealand
            Without something to spread out the airflow in the nozzle you will have big problems - by the time you melt the balls on the outer edges of the chip the center will be overheating. You could test with a probe in the center and one by the edge. Or use an IR thermometer...
            I don't think tape will help. Isn't that the tape used to protect surrounding components from heat? It's just going to block heat from reaching the IC properly, I suspect.
            I saw a good thread on another forum about this same issue. I'll try to find it again, it was quite interesting.
            -David VanHorn
            • ravenns
              • Mar 2013
              • 5
              • Serbia
              #26
              Cool guys!
              I use 2 probes one on the left and right side of the chip (if You are looking from above at the chip), sometimes up and down sides of the chip (if You are looking from above at the chip).
              Like this ( * - marks the spot where the probes are):
              //......CHIP......//-OR---*//......CHIP.......// *
              My profile:
              0. Kingbo around the chip
              1. Preheat until 150-160/170*C
              2. Hot air - to 260*C until reading on the thermometer is at 190*C
              3. Hot air - to 300 - 330*C max then poking the chip untill ready
              4. Lifting
              5. Cooling the board on it's own until 150*C then turn on the fan
              6. Cleaning the chip with ZD-99 knob set at 1-2 o'clock
              7. Also, cleaning the pads on board with the same settings of ZD-99
              8. Put solder balls on, and then hot air set to 260*C about 5min until all the balls are melted
              9. Next, Kingbo flux both board and chip
              10. Aligning the chip?!? ****this is tricky for me if anyone have any suggestion....****
              11. Bottom heater until 150-160*C
              12. Hot air set to 230-240*C until chip "sits" about 60sec more after chip sits
              13. Cooling on it's own until 150*C, then fan
              This is all, if anyone have anything to add, or correct me, please do so...
              Thanks in advance!
              • xboxhaxorz
                • Jan 2011
                • 196
                #27
                Thanks guys!
                About desoldering wick... I use (I guess) it's the goot wick - I know it is bad... I'll try today to do a laptop motherboard, and I'll get to all of You soon...
                Thank You again!
                Goot is horrible wick
                Chemtronics
                MG
                Those work well
                But i have personally not found a wick that works as well as this stuff
                http://www.youtube.com/watch?v=3fceVikYw1o
                Note: most of our videos show us using products we sell, so you may consider this advertising but the videos also show our techniques so while i do not do any direct advertising on forums our videos show products in use
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  I'm back, i've been quiet as it's not the nVidia G86-730-A2 chip which arrived, but an earlier order. A BGA holder for reballing. The lift tool is due to arrive tomorrow, so i'll have something to play with until the chips arrive, i can lift the bad ones and clean the boards.
                  • xboxhaxorz
                    • Jan 2011
                    • 196
                    #29
                    lol its called vacuum suction pen
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      EEVblog 437 (at 8:50 mark) shows Dave using some blue tack on the end of a screwdriver. The actual lifting at 11:54 mark.
                      --- begin sig file ---
                      --- end sig file ---
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5086
                        • New Zealand
                        #31
                        Heh, I saw that too.
                        I just use tweezers. If it's a large part, grab it by a corner\edge. So far haven't needed anything else.
                        -David VanHorn
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #32
                          The vacuum pen-like tool wasn't that expensive... and it can lift surprisingly large/heavy stuff for its size so i likely will be using it for more than BGAs. Definitely gonna come in handy.
                          • xboxhaxorz
                            • Jan 2011
                            • 196
                            #33
                            tweezers wont work, as you will probably lift pads
                            the vacuum tool provides usually just enough umph to lift
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #34
                              That's exactly why i got it. Btw, i got it off you, as it was the only one i found on ebay that didn't come bundled with all sorts of other (more expensive) crap i don't need right now, like a lot of stencils or a can of flux.
                              • xboxhaxorz
                                • Jan 2011
                                • 196
                                #35
                                oh cool, enjoy
                                yes i figured that it should be sold alone too
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  #36
                                  Thanks. It works quite well actually, with one little gripe: Only the largest suction cup works properly.
                                  After my first FAIL (the DV9000, because i didn't have the proper nozzle for the hot air station, and i couldn't heat the whole chip uniformly), i can now proudly announce my first VICTORY!
                                  HP DV5, ATi HD3450 (216-0707011) video chip. Board had been reballed before, but likely overheated or something, as the corners of the GPU were raised. It fired up from time to time with corrupted gfx, most of the time it just shut down by itself after 1 second.
                                  I replaced the chip with another one, that i bought pre-balled from ebay. In fact, i got lucky, as the seller didn't mention that, so i also got stencils and solder balls, but that's what i got. Replacement chip seated itself perfectly, and IT'S ALIVE!!! I was kinda worried about the NB, as it too has raised corners, but it appears to work. We'll see once i fully assemble it and run some stress tests.
                                  • edugimeno
                                    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                    by edugimeno
                                    Hi!!
                                    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                    At a certain point, moving stuff around, I put all wires back in place and...
                                    03-24-2024, 02:31 PM
                                  • madan1
                                    Diesel heater emergency power supply / poor man's UPS
                                    by madan1
                                    Hello everyone.
                                    Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                                    12-18-2022, 08:05 PM
                                  • DynaxSC
                                    Each GPU reballing produces different MATS results, looking for root cause ?
                                    by DynaxSC
                                    I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
                                    1. When I received the card Mats showed one memory with errors.
                                    2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
                                    3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
                                    4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
                                    5. Made...
                                    12-11-2024, 07:44 PM
                                    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                    12-16-2023, 08:39 PM
                                  • sew333
                                    Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                                    by sew333
                                    Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                                    So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                                    So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                                    I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                                    06-14-2024, 07:30 AM
