So, I have figured out a way to mount SMT components on perfboard.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    And no, I'm not talking about putting SMT components on the solder pad side, I'm talking about solder pad adapters for the top side of the board... essentially through hole solder pads. They are called head pins, and used for making jewelry although admittedly I have no clue exactly how they are used to make jewelry... I just found them in the beading section at Walmart while looking around a couple weeks ago, but had to go to Hobby Lobby to get solid copper ones because the ones at Walmart were all plated steel.
    Anyhoos, to make a long story short, it turns out that the head part is just about the size of the solder pad on the bottom of your typical chinese perfboard which also just so happens to be the same width as your typical 1206 case resistor or capacitor. My plan is to strip the head pins of any coatings via chemical or abrasive means, grind them with the rotary tool giving the head a flat side ala waxing or waning moon shape, then whack them with a punch to flatten out the wire lead a little so it can grip the inside of the perfboard's through hole, pull them in place with some pliers to prevent them from rotating once in place, and then snip the leads flush with the perfboard's solder pad so that any trace wires can be laid flat on the pad and easily tacked into place.
    The only other problem is that man are those little SMT components slippery... soon as the solder on the pad liquifies they want to go all over the place! Furthermore best results I have obtained is by pre-tinning the solder pads and using dual irons with my previous generation of SMT adaper... the pins going to parallel port headers on junk motherboards. I will definitely need some sort of "holder downer"... I have an idea for one using the metal rod that a CD/DVD laser sled rides on fitted with a spring, some washers, and a couple "e clips"... something like a pogo stick tester used at sparkfun only a lot bigger. With something like what I am hoping to rig up it will apply constant down pressure on the component with the spring loaded tip while keeping it from rotating, and as soon as the joint liquifies on both sides, it will press the component flat on the pre-tinned pads.
    Updates as soon as I get around to trying them out... I need to whip up a few linear voltage regulators, but I'm out of blank perfboard PCB's at the moment.
    • Jul 2011
    • 6057
    Re: So, I have figured out a way to mount SMT components on perfboard.
    When you are done with tis board can you take some photo of it so we see what it looks like Thanks
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      Well I finally got round to doing a test. Turns out flattening the leads is easily accomplished with a pair of pliers, and once pulled into place the pads are fairly steady. Pre-tinning the heads results in a fairly decent filet joint, and as long as the leads are not soldered into place it should result in a fairly stress free joint.
      For a test I used a 1% (or it may be better) precision 1206 case resistor. Below it are a couple unground head pins showing how they look when placed in a through hole, and another two head pins are shown on top, one with the top flattened to keep it from rotating in the through hole.
      Sorry couldn't get a better pic, my camera doesn't do close up shots worth a damn at all.
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • corrize
        Best way to solder LVDS connector for beginner (and qfn) ?
        by corrize
        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
        See the test :
        https://youtu.be/bNAzC-EvqHs?t=1767
        With hot air from bellow the board, that's...
        03-09-2023, 02:57 AM
      • myth77
        UV solder mask - high temp resistent, recomendation?
        by myth77
        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
        Is there any solder mask...
        03-28-2022, 04:04 AM
      • petemanuk
        BGA solder balls not connecting - help pls
        by petemanuk
        So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
        I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
        I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
        11-16-2022, 05:21 AM
      • Jeff'sTech
        Dell Latitude 7420 BIOS Unlock Gone Wrong
        by Jeff'sTech
        Hello everyone.
        I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
        11-08-2023, 03:30 PM
