How do you test a Schottky Barrier Diode
  • johnnydiaz
    • Apr 2012
    • 52
    I'm troubleshooting a smps and trying to understand how to test a schottky barrier diode. Below is the link to the datasheet. Can someone describe the method?
    http://www.htmldatasheet.com/niec/fch06a10.htm
    Thanks,
    Johnny
    Re: How do you test a Schottky Barrier Diode
    You test it like any regular, silicon diode.
    It should conduct in one direction, and not in the other.
    • iyas132
      Corsair RM 750 blown schottky diode near ES1DF
      by iyas132
      Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
      Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
      My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
      Can anyone help me identify the component...
      12-30-2024, 01:34 AM
    • dj8452000
      How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
      by dj8452000
      I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
      02-18-2025, 08:28 AM
    • howardc64
      QN75QN85BAFXZA no backlight
      by howardc64
      2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
      PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
      07-03-2025, 05:08 PM
    • Baste
      MBR3045CT and SR3045LCT Schottky diode testing help.
      by Baste
      Hello experts,
      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
      Aneng ST182 Meter.
      Diode mode.
      MBR3045CT:
      Diode mode
      Pin 2-1 - 0.150v
      Pin 2-3 - 0.150v ...
      10-21-2025, 06:14 AM
    • MalodicOne
      macbook pro 820-02100 5v 0 amp
      by MalodicOne
      Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
      Tested all CD3217 and RAA489900:
      UF400
      PP3v3_UPC0_LDO- 3.48v, .473 Diode
      PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
      USBC0_CC1- 0v, .455 Diode
      USBC0_CC2- 1.66v, .454 Diode...
      07-25-2025, 10:49 AM
